Thread: Intelitouch remote reading sensor error- solar
    We are in the process of getting our home painted. Today when I got home the remote is reading sensor error- pool solar sensor
    How can I trouble shoot this before I need to call out the pool repair guy.
    Thanks in advance!
    Cheers!
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Re: Intelitouch remote reading sensor error- solar
    Usually that means the sensor has been disconnected. Follow the wire from the control unit to the solar sensor on the roof. Perhaps the painters have broken the wire or pulled it out.
    Thanks Jason. Found the tear. Do I need to reset anything once I have fixed the wire?
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by dykes26
    You shouldn't have to reset anything, however, if you're splicing the wire back together make sure you use waterproof connectors (the sensors really don't like added resistance in the circuit-ruins their whole day, and makes their readings inaccurate)
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
