Thread: Liquidator Online
    Liquidator Online
    So, it took forever for the LQ to show up, due to coming from the west coast and the free shipping....but it arrived in one piece with the 3/8 upgrade and I spent the evening plumbing it in.
    Since I do have an AGP, I was concerned about flow. I do have a skimmer and a main drain, but the pump is on the low side of the pool, nearly at ground level and about 4ft from the pool.
    I opted to use 1 1/2" T's with 1/2" pipe threads built in along with 1/2" pipe to 3/8 quick connects to make the connections to the LQ, since I was doing some other work at the same time.
    With it fired up, I am able to get to about 4.25 on the flow gauge, if I restrict the 3-way valve that mixes the skimmer and main drain, I can get it to max out. With both on 50/50, I can easily sustain 3, and max it out over 4 as stated above.
    The questions: am I good to go? Or do I need to run restricted?
    I only was able to put 2 gallons of chlorine in the unit as it was getting dark...went back out with a flashlight to ensure there were no leaks...still seeing yellow in the bottom and no leaks.
    The metallic water generator and cyanuric acid dispenser have been retired. :
    Oh, and I left the tails on the wire ties, I hear this helps the FC...
    13,500 / AG / Vinyl / Hayward 150 sq ft Cartridge / 1HP 2 Speed / Born in 2009
    Intermatic Timer / Stenner 10GPD + Woods Timer / Former LQ (3/8 upgrade and SMC Valves) 2012
    Re: Liquidator Online
    It sounds like you are getting plenty of flow and should be fine. From here it is just a question of adjusting the flow rate on the liquidator to get the target FC level you need for your CYA level.
    22,553
    it's surprising at the magic leaving the tails on the zip-ties creates!
