Results 1 to 11 of 11
Thread: electric
    Jul 2012
    Georgetown, KY
    31
    electric
    Currently having to run an extension cord to operate our agp(temporary). We have called multiple electricians, finally got a call back today from one. They came out and looked and told us they would give us an estimate by next Thursday. I know nothing about the electric stuff. I want a plug that can work for deck lighting in the future too. Is there a lot of work required for them to do this? I guess I'm just trying to figure out a price estimate, so I know I'm getting a fair price. Any info is appreciated!
    Morada AGP 24 foot, 52 inch deep
    DE filter, 2hp pump, inline chlorinator
    Set up on July 1st, 2012
    Goal is to use the BBB method!
    VERY new to the pool scene!
    Love the Pool School, still learning so much!
    Thank you in advance for your advice and help!
    Jul 2009
    Olney, MD
    218
    Re: electric
    Can't comment on the price, however, I know a lot of pumps are supposed to be connected to their own breaker. Maybe that is different for AGP...
    I really hope you opted for a GFI type of extension cord for your temporary fix (or at least unplug it while people are around the water).
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Re: electric
    I had mine hooked up with an extension cord for 2 years and my electrician was indifferent on me using it. I wanted deck lighting as well so I finally had him bury a dedicated outlet and mount it on the deck and he charged me $300.
    Jul 2012
    Georgetown, KY
    31
    Re: electric
    Husband said it was plugged into a gfi outlet. I am anxious to know how much its going to cost and I will be glad to have it done!
    Re: electric
    Most of the work is usually digging a trench to bury the electrical cable/conduit in. The challenge of doing that varies quite a bit depending on how far it needs to run and what is in the way. Often you can get a big price break if you dig the trench yourself.
    Re: electric
    I think I got completely ripped off based on this. I paid over a grand to get a new panel in the house (you may not need that - my house one was almost full when I started the pool project.) Then I paid just over a grand again for the guy to get six feet away from that area (outside the house) to mount a new breaker box and three outlets, as well as bond everything. On that second bill, he was installing the heater and pump. I'll have to eventually pay more as that did not include a timer or a "kill switch" or whatever you call it so I can turn the pump off without opening up the dedicated breaker box. Good luck - hopefully yours is way less money/involved.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jul 2012
    Georgetown, KY
    31
    Re: electric
    Thats what I am nervous about. I don't want to get ripped. grrr.
    Jul 2012
    Georgetown, KY
    31
    Re: electric
    The electrician that came said there is plenty of space in our breaker box. and then the pool pump is approx. a 100 foot from the house/breaker box.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: electric
    I know we did ours ourself. My husband and bother-in-law, drilled through the basement wall to put a gfi connection out back. Then my husband and I dug the trench and ran wire through conduit to the pool area. We put a gfi connection under the deck for the pump and light and another outlet on top of the deck for music and such. It wasn't really hard, digging the trench wasprobably the hardest part. Probably was lessthan $100 for the whole setup, wire conduit, recepticls, etc.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: electric
    Digging the trench is the killer.
    I'm no professional electrician, so I don't know all the figures, but I do know there are figures for how deep the trench needs to be, how high above ground the boxes need to be, and how close/far away from the pool the outlet can be. Grill your electricians, "What does code say?" and only hire the guy who can give you the answer, even if he's not the cheapest.
    Anyone with a little bit of mechanical aptitude can install a circuit breaker and string some wire. That's not good enough. You don't want the end result to look like something out of http://failblog.cheezburger.com/thereifixedit/
    Jul 2012
    Georgetown, KY
    31
    Re: electric
    After reading info via the internet I am considering doing some of the work ourselves to save money. Wish I had a basic list of requirements, how to's, etc.
