Results 1 to 8 of 8
Thread: Struggling to lower TA
    May 2011
    Rochester, MN
    44
    So I had the best of intentions to add borates this summer (7 boxes of 20 mule team in my garage), but I am struggling to decrease my TA to reasonable levels. My TA has consistently been hanging around the 200ppm range. I have been constantly aerating with my return jet, letting my pH climb to the 7.8-8.0 range and then knocking it back down to 7.0-7.2 range with muriatic acid. Unfortunately, a few bottles of muriatic acid later, I don't seem to be making much headway.
    It had been raining a significant amount a couple weeks ago, but I figured that would only help since rains pH is around 5.
    Anyway, if anyone has any further suggestions, I would appreciate it. With a vinyl pool, what should be my goal TA before adding borax? Thanks!
    Matt
    24ft round AG, 13.5K Gal, vinyl, 1.5HP Pentair Dynamo pump, 22" Pentair Meteor sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Struggling to lower TA
    What is the TA of your fill water?
    You're done SLAMing when:
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Can you double or triple up on the aeration?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    May 2011
    Rochester, MN
    44
    I don't have any other methods of aerating, just my one return jet.
    Fill water TA = 300
    I just tested my pool TA and it was 175 and my pH was 8, so hopefully when I add the appropriate amount of MA, I will be under the 150 mark for my TA.
    What should I shoot for?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html?hilit=want%20borates says 70-80 is your target.
    In the article in pool school on how to reduce TA, there are links to pictures of some homemade aerators.
    May 2011
    Rochester, MN
    44
    Do CYA levels have any effect TA levels? Thanks!
    38,284
    No. Only CYA affects CYA levels.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Feb 2008
    Denton, TX
    5,061
    Some people can get their TA down with relative ease while others may spends many weeks trying to get it down. I see that with your fill water TA being 300, you are really going to have to battle it down. I think that how disciplined you are at keeping that pH at 7.2 is what will determine the length of time it will take. Definitely avoid adding boartes though until you have the TA exactly where you like it to be. Once you have borates in there, you probably won't be able to budge it.
    I agree with Richard...go for a TA of around 70 to 80.
