Thread: Pumping Water Out of Pool
    Jul 2012
    Peoria, AZ
    7
    Hello all,
    I will be renting a sump pump today and pumping the water out of my pool to lower my CYA. I have a float that automatically adds water to my pool to counter evaporation. Can I and should I manually disable this while pumping the water out? If so, how?
    Thanks in advance.
    9500 Gallons, IG, Pebble, Cartridge filters, 1.5 HP Pump, Built 2005 - Peoria, AZ
    Apr 2011
    Lynchburg VA
    393
    Re: Pumping Water Out of Pool
    If you cannot separate the new water coming into the pool from the old water going out, disable the auto fill. When you have drained what you want to drain, fill the pool back up. If you have a tarp that will cover the top of the pool you can cover the pool, pump water from under the tarp, refill the pool on top of the tarp and the remove the tarp allowing the water to mix when you have drained what you want to drain.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    There should be a shutoff valve for the line feeding the automatic pool leveler. If you can't fine it, then tie the float up inside the leveler to shut the water off.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
