Thread: Results from TF-100 Kit-Pool Calculator results?
    Jun 2012
    Hudson Ohio
    47
    Here are my test results
    PH 7.3
    FC 5.5
    CC .5
    TA 330 (has always been high)
    CH 140
    Pool calculator recommends adding 36oz of Borax..Won't that raise my PH and TA
    We are not having any issues other than having to add stabilizer for the CYA.
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    Re: Results from TF-100 Kit-Pool Calculator results?
    The Pool Calculator never recommends anything. It simply tells you how to adjust your levels to the numbers you have entered in the target column.
    In your situation, there is no need to raise the PH. The PH will tend to go up on it's own because of your high TA, and doesn't need any help.
    Jun 2012
    Hudson Ohio
    47
    where do I get my target numbers..May have missed that in the Pool school
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mtucker
    Yep, it is a lot to read
    pool-school/recommended_levels
    You're done SLAMing when:
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    With your high TA, you can ignore pH until it gets up to 7.8. Once there, put 7.2 in as your target pH, making sure you have your current TA entered.
    For your FC goal, take your minimum number, based off your CYA and add 4 to it. Most pools lose 2-4 ppm per day, so this is a safe place to start.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
