Thread: Final Drawing - Input Appreciated
    Jun 2012
    Austin, TX
    97
    I received the final drawing for our pool. The back portion of the pool will have an 18" raised wall with 2 water sheers. I'm a little concerned about the width of the pool. It is 15' 3" on one end, 14' 3" in the middle, and 19' 9" on the end with the tanning ledge. It is 34' 3" long. Do you think that will be too narrow in the middle? Should I take a foot or so off the length and widen the pool a little? I guess what I'm asking is for is experiences from those who have pools...would you prefer a shorter/wider pool or a longer/narrower pool.
    Any input would be appreciated
    32x15 freeform gunite pool (approx 15,000 gallons) with a 7x7 raised spa with 2 spillovers - tanning ledge with 2 bubblers - All Hayward Equipment - ARQ15 SWCG - 400btu heater, 60sq ft DE filter - 2HP EcoStar VS pump - Oklahoma flagstone coping - MasterTile MASMIX 3 1x1 - Sundek - Crystal Stones Smooth Caribbean Blue - TF-100 - Doheny's Discovery Robot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Final Drawing - Input Appreciated
    It's your preference. Is someone going to be swimming laps? Then longer. Playing volleyball? Keep it shallow.
    My only design advice, based on what I'm stuck with, is to have your skimmer be at the downwind side of the pool, even if it means the longest pipe run. My returns are not able to overcome even a light breeze - everything floats on by my skimmer, ends up at the downwind end, and sinks there.
