Thread: After switching from pucks to liquid, my pool has never...
    looked this great
    Before, it was 3" trichlor in the chlorinator, set to 4 or so, and always fighting high CYA, cloudy water, shocking back algae blooms and brushing 2x weekly. After getting the TF100 kit, draining half the pool and some trial and error through the early summer, I think I've got it nailed. A 3-4 second daily pour of the 10% keeps my FC at 4 or so, and a few 3" pucks set at low keeps a low dose of CYA into the pool to make up for splashout and backwashing. pH and CH good and CYA at 40-50, no visible algae on walls or steps and just brush 1x weekly for maintenance. Great site and info here, just thought I'd share
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: After switching from pucks to liquid, my pool has never.
    I agree texsn95. My has never looked so clear and sparkling!!!!!!!!!!!!
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Quote Originally Posted by texsn95
    looked this great
    Do keep track of how many pucks eventually dissolve, as each is adding 4-6 ppm of CYA. It sounds like you have a handle on it though.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,768
    My friends were in from the east coast last weekend and couldn't believe how "silky" and "nice" my water felt (I am using borates as well.)
    So yeah, great job BBB community In my case, since I was new to the pool, I never had the "pleasure/horror" of doing it the puck-feeder way, thanks to the advice on this site.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sounds like it is going well...remember those pucks add cya, and cya does not magically leave the pool, except when the drain/refill fairies come by. You cya level is likely going up, so your target FC level also will be going up. Since you are at about 50 ppm right now, stop using the pucks and use the liquid chlorine to keep your FC always above 4 ppm 24/7.
