Thread: Variable speed Pump and SWG
    Feb 2010
    Central NJ
    53
    Hello All
    I've been thonking about swaping out my pump for a Variable speed pentair in order to cut energy consuption. My question, How will this effect my chlorine generation on the SWG. I assume i would need to run my pump longer in order to make up for it, or do i just raise the % of chlorine?
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Jun 2011
    Long Island, NY
    92
    Re: Variable speed Pump and SWG
    I have a variable speed Ecostar and all you really need to do is find the lowest speed that the SWG will detect flow through the cell and produce chlorine. Then simply work your pump times and percentages as normal knowing that if you set the pump to run at a lower speed than that it will not generate chlorine.
    25K Gallon IG Vinyl Liner w/ concrete walls True "L" 16X32X16, Hayward EcoStar VS pump, Hayward Swimclear C4030 Filter, Hayward 21104T Heat Pro Titanium Heat Pump, Hayward Aqua Plus SWG + Automation, 2 Hayward Color Logic 4.0 LED lights, Polaris 9300 cleaner. TF-100 test kit.
