Thread: CYA test results, still 0 ?
    May 2008
    Austin, TX
    27
    Forgive me if this is a silly question, I've been languishing in Baquahell for 3 yrs and am new to the chlorine numbers.
    Yesterday morning I started de-gunking my pool per Jasons sticky on algea removal, I put 2 lbs of CYA in a sock in the skimmer, this morning I tried to do the CYA test and the water remained clear after I added the CYA reagent, I filled up the tube and could still see the dot. Does this mean there's no CYA in the pool? Or did I just mess up the test?
    The sock from yesterday was 3/4ths gone this morning so I put more in.
    My info
    I have a 12'X28' AG Doughboy, a little over 7900 gal. Haywood pump and sand filter
    FC-still high this a.m., it stayed a med orange color overnight.
    pH- 7.2
    Total Alk- 130
    CYA-?
    I'm ordering a "real" test kit today.
    The water is still milky but is BLUE now
    12' x 28' Doughboy, partially underground, 9100 gal. Hayward pump and sand filter, Barracuda Zippy pressure side cleaner.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It can take up to a week for CYA to get into the water. It's no big deal, but you don't really need to be in a hurry to get CYA in the water while you are converting, because it tends to slow the chlorine down a little, and you are already adding chlorine so often that the sunlight loss isn't an issue.
    30,415
    JC,
    John's right. I would even suggest adding no more until your conversion is complete.
