Results 1 to 7 of 7
Thread: hypothetical question.
    Oct 2010
    michigan
    284
    what would happen if i added 2200 lbs of baking soda to my pool? then used the reverse to get the chemistry rite again. miratic acid and borax to get the numbers back in range.
    hypothetically say you did these at the same time keeping things balanced.
    would you have excess of other by products in the baking soda? miratic acid? borax?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: hypothetical question.
    Is the 2200 lbs a typo? Your TA would get unpredictably low, and your pH would get very very high. Adding Borax would make pH even higher. It would require a dangerous quantity of MA to take everything back the other direction.
    Please reply with a full set of test results, and a quick idea of your end goal. Do not put 2200 lbs of Baking Soda in your pool.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Oct 2010
    michigan
    284
    its a hypothetical question
    curiousity, fun
    Mar 2007
    San Rafael, CA USA
    12,082
    You wouldn't need the Borax. You'd just use acid and aeration to lower the TA back down. What you would end up with is sodium chloride salt -- the sodium from the baking soda and the chloride from the Muriatic (hydrochloric) acid while all the carbonates would be outgassed as carbon dioxide. 2200 pounds of baking soda in 15,000 gallons then later adjusted to remove the 10,470 ppm TA would result in 58.44/84.007*2200 = 1530 pounds of salt which is 12226 ppm salt.
    Oct 2010
    michigan
    284
    thanks for entertaining me chem geek lol
    Jul 2009
    Olney, MD
    218
    Quote Originally Posted by elwood58
    No, the TA would get high!!!! Very high, as baking soda raises TA.
    I also think it would take years to accomplish acceptable levels through aeration to remediate the created problem.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Yeah, I was being hypothetical in my answer as well, but in practice the large rise in TA would cause significant scaling, cloudiness and precipitation of calcium carbonate unless the CH were very low (20 ppm or less).
