Thread: Neighbors backwash
    Mar 2012
    Kansas City, MO
    59
    Neighbors backwash
    My neighbors got a huge, gorgeous pool. He doesn't do any maintenance himself, so every Wednesday his pool service company comes to clean it. They backwash into the street, and it's so full of chemicals, the street is stained with white streaks and patches. Is this is normal when not using BBB?? I mean, I'm new to this whole thing, but even still, seeing that stuff come out of my pool would make me question whether or not I should be swimming in that water.
    I meant to take a couple pics, but forgot. I'll try to snap one later...
    15k gallon IG kidney pool with attached spa
    plaster
    sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Neighbors backwash
    If he has a DE filter, that white stuff is DE. or cellulose. And more than likely, it's illegal to dump it in the storm drains.
    And a weekly backflush is overkill, but it probably helps the bottom line.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I agree that it sounds like DE, and weekly backwash is overkill.
    I am always discussed at what comes out of my Sand Filter when I backwash. I am sure glad it is taking that stuff out of my pool.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    My backwash line goes underground about 20 ft away or so to a spot in my yard. I put gravel in the hole where it ends up so it doesn't get to packed, and it waters the lawn when I finally do backwash which is not very often.. ~2 weeks at least.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Quote Originally Posted by elwood58
    Now think about us with Cartridge. Our perfectly clean, white, new filters come out BROWN.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
