Thread: Pool light wet niche bonding/grounding wire
    The bonding/ground wire attached in the pool light wet niche has come undone. It is connected to a post that was cemented/glued to the brass niche.
    What do I use to reconnect as welding won’t work on this. Also, once fixed in place, do I cover the wire and connection with a rust inhibitor?
    I had a separate thread on this light that can be viewed here to see the niche.
    pool-light-for-old-sylvan-pool-t45374.html
    22,543
    Re: Pool light wet niche bonding/grounding wire
    If the conduit is metal you can use a grounding clamp to reattach the bonding wire to it.
    Jun 2012
    western NY
    1,559
    If the niche is brass as you say, the wire was brazed/soldered to the niche. You will have to re-attach it that way. The bond wire there serves two purposes, one to bond the light itself and the other as a waterbond.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
