Results 1 to 8 of 8
Thread: TF100 new user - FC reading way different from Pool Store
    TF100 new user - FC reads much lower than Pool Store
    I am new to this site, great info. I have cloudy water. My test for FC using TF100 says about 1.5 and the pool store says 12. What am I doing wrong? I have used more DPD Power for test and got the same results. On the OTO test I can see it is over 5. Help plz.
    40K gal, vinyl, 1 1/2 Starite pump, Sta-rite cartridge filter, tiger shark cleaner
    I am new to this site, awesome place. I just got my TF100 and compared my numbers to my pool store. All my number are close except the FC I have 2 and they have 12. What am I doing wrong?
    30,421
    Re: TF100 new user - FC reading way different from Pool Stor
    Going to the pool Store!!
    Always, Always trust your own testing. I assume you are doing the FAS/DPD test for chlorine. If your 10 ml pool sample turned pink/red when you added the powder, you have chlorine.
    If it turned back to clear on the 4th drop of R-0871, then you have 2ppm FC....it's really that simple and points out the futility in trying to manage a pool properly with reliance on pool store tests.
    Review the procedures of the test to insure you followed the directions and then start saving gas money (and more) by staying away from the pool store.
    Trust your own measurements
    For peace of mind tell us what steps you tookto get your results be fairly precise how much water how many scoops drops etc.
    24' 52" Above Ground
    BBB
    LOVE TFP
    TF Test kits, Pool School, Pool Calculator
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    mrblaine:
    Welcome to TFP
    In all likelihood, you are not doing anything wrong. As you become more familiar with this forum, you will learn to trust your own test results over the pool store's. Pool Store test results are notably inaccurate.
    Which test did you use to measure chlorine - was it the FAS-DPD test (the one that uses the powder) or was it the basic OTO test (the one in the small blue box )?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    If you did what duraleigh said, then ignore the pool store reading. And be 100% confident that your reading is the right one.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    22,550
    Welcome to TFP.
    Most likely the pool store is testing TC. The OTO test is TC. What that means is that you have 1.5 ppm FC and 13.5 ppm CC.
    You need to start the shock process and stay with it until you pass the OCLT and the water is clear.
    How are the rest of your numbers looking?
    23,000 gallon gunite with waterfall, radiant heat, sta rite system 3 cartridge filter 450 sq. ft., 1 1/2 HP
