my pump will only half fill the pool is 3,861 gallons only half of the filter is being used i use the air valve but it will not spit out water just keeps feeeding more air it will not fully fill up what is the issue?
You have a suction side air leak. Somewhere between the pump and the skimmer(s), air is being sucked into the system. Find that leak and your issues will be solved.
i just went outside at 1am lol it worked thanks so much you may close this post i also have milky water but thats cuz i skipped the ph stuff lol thanks guys
By the way, duraleigh was right, it was a suction side leak, called a open air bleed valve since those intex pumps have the filter on the suction side.
