Results 1 to 9 of 9
Thread: Krystal Clea Model 637R Filter Pump Help
    my pump will only half fill the pool is 3,861 gallons only half of the filter is being used i use the air valve but it will not spit out water just keeps feeeding more air it will not fully fill up what is the issue?
    30,419
    Re: Krystal Clea Model 637R Filter Pump Help
    You have a suction side air leak. Somewhere between the pump and the skimmer(s), air is being sucked into the system. Find that leak and your issues will be solved.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Galarius
    Any chance the level the filter fills up to is the same vertical level as the pool surface?
    the pump is sitting way below the wter level if thats what you mean sorry kinda new to pools
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Are you bleeding the air with the pump off? It needs to be.
    OHHHH!!! so i shut the pump off till it spurts water than close it?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yep
    i just went outside at 1am lol it worked thanks so much you may close this post i also have milky water but thats cuz i skipped the ph stuff lol thanks guys
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    By the way, duraleigh was right, it was a suction side leak, called a open air bleed valve since those intex pumps have the filter on the suction side.
    Beware, milky water is often a sign of algae
