Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Just setup and turned on Intex SWG
    Jul 2012
    Long Island, NY
    16
    I have an 18' x 48" Intex Easy Set pool which is approx 5,500 gal. I put in 135#'s of salt as stated by Intex. I ran my pump for 24 hours then turned on the Intex SWG. Within 5 min it threw a Code 91. I turned off the SWG then back on and 15 min later is blew the Code 91 again.
    I can't provide any testing numbers as I have not gotten a kit as of yet. I am a complete newb when it comes to pools, just got this and honestly didn't think I needed to worry about getting one. I thought this would be a simple "Plug and Play" kind of thing. Now after finding this site yesterday and doing some reading I am seeing how much I truly need to learn. Going to order the TF100 kit tonight and take water sample to the local Leslie's Pool for testing for now.
    Anyway, getting back to my current issue... If I keep running the SWG with the Code 91 will it try and create Chlorine or am I wasting my time? Any and all advice is greatly appreciated. Any more info I can provide will come as quickly as possible.
    Thanks
    Larry
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Just setup and turned on Intex SWG
    If you pool is 18X4 then it is typically filled to 3.5 feet for a volume of 6423 (that is from intex documentation).
    So 135 lbs would have only brought you up to ~2500 ppm salt and the intex swg will likely give the 91 code at that low salt concentration since their range is 2500-3500 ppm.
    Jul 2012
    Long Island, NY
    16
    Linen, I have the Easy Set Pool which is 5,455 gallons. The 6,423 is for the Circular Metal Frame Pool.
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by spdrcr5
    Sorry about that Yes, with that pool I get 135 pounds should raise you to 2950, which should be right.
    Do you have a salt test that you can confirm your concentration with?
    Another thought...were you using 40 lb bags instead of 50 lb bags (and assumed they were 50)? I have done that. That would give you about 2500 ppm salt.
    You may just have to give it another day and see if there is just a little more salt that needs to dissolve to make the swg happy. Also, I run my intex just a little higher at 3400, per the pool school recommendation. I wouldn't add any more yet until you get a test result for salt.
    Jul 2012
    Long Island, NY
    16
    I double checked and the bags are 40. I bought 4 of them. Walked around the pool and poured the salt in for each bag. Then I weighed out 15lb from the 4th bag and poured that in. The only thing I didn't do was weigh the bags before pouring then in. Maybe they aren't actually 40?
    Al I have are those test strips that came with the pool. I tried one last night and none of the colors looked right... But that could just me doing it wrong.
    I poured in another 5lb last night "just to see" if that would do anything. This morning I have a lie salt light on the swg. I switched the pump on instead of using the timer and restarted the swg to run 8 hours. I will see what's going on when I get home from work in 13 hours.
    Going to call Intex today to see what they tell me.
    How much salt do you think I should have started with? Figure at this point I have put in 140 and still have a code 91. I still have approx 20lb left.
    Going to bring the water to the pool store just so I have some numbers.
    Thanks
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I wonder if not having any CYA in the water would cause the SWG to code? Larry didn't say he put any in, so I'm assuming he didn't.
    Larry, you'll need to add Cyanuric Acid, enough to raise it to 70-80ppm. So while you're at the pool store, get some. If it's more than 15 bucks though, pass and pick it up at Lowes or Walmart. Last I checked pool store CYA price, it was $30. I passed.
    Also, I think it would be prudent to not rely on the SWG at first and to dose your pool with bleach up to 6ppm (once the CYA is in) till you get this figured out. If you don't chlorinate soon, you'll have a green swamp. Switch gears and read Pool School and consider this pool a true BBB pool for now. It will mean of course chlorinating daily with bleach, and as always, even with a SWG a good test kit on order or in your hands.
    See if the pool store will give you a salt reading and let us know. I'd put some bleach in the pool today, before you leave if possible. 2-3ppm only since you have no CYA (use Pool Calculator).
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2012
    Long Island, NY
    16
    I was already on the train when I replied to the thread before. Just got to the office...
    I can't do anything until I get home tonight. I guess I will not be having a pool party tomorrow at my house.
    I will get the water from 2' down and bring it for testing. I can stop at Home Depot and see if they have Cyanuric Acid, is that what it is actually called or is there a company name or something that I need to look for? What part of the store would I find it? How much would I need to add to 5,500 gallons?
    Which Pool Calculator should I be getting? I have an Android phone and see several different ones.
    Thanks.
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    Jul 2012
    Long Island, NY
    16
    One more question. Before I get the salt figured out and can get the Cyanuric Acid level up. Would it be alright to swim in the pool tomorrow? The water is crystal clear, looks exactly as it looked when I first filed it Tues/Wed. We have about a dozen people coming over for a lunch pool party.
    Thanks again.
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    22,551
    Cyanuric acid is stabilizer or conditioner. It's in the pool section.
    As long as there's FC in there it's fine to swim.
    Jul 2012
    Long Island, NY
    16
    Thanks, any ideas how much I should purchase? I can have my wife get it today and pour it in while the pump is running. Should I turn off the SWG or leave it running as I currently have it?
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    22,551
    If we can assume it's zero now you'll need about 3 lbs.
    Jul 2012
    Long Island, NY
    16
    It should be Zero since all that's in the water is ~140lbs of Salt.
    Thanks, I will have my wife pick some up and pour it into the water.
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Before adding anymore salt, I would at least get a reading at a pool store, but even better would be dedicated salt test strips. These are the ones I use: http://tftestkits.net/Salt-Test-Stri...-Chek-p28.html.
    Salt can only be lowered by a partial drain/refill.
    Quote Originally Posted by frogabog
    CYA does not affect salt readings.
    Jul 2012
    Long Island, NY
    16
    Since you are saying I need 3lbs, is it a powder or a liquid? If liquid does it need to be weighed? I checked the pool stores site and they show it in gallon jugs as well as smaller sizes but it is all liquid.
    I just want to make certain my wife gets the right stuff before pouring it into the pool. Also, I look on the Home Depot website and they don't list this as being available. Do they carry it or should I have her try WalMart, Target or somewhere else?
    Quote Originally Posted by linen
    Before adding anymore salt, I would at least get a reading at a pool store, but even better would be dedicated salt test strips. These are the ones I use: http://tftestkits.net/Salt-Test-Strips- ... k-p28.html.
    I plan on ordering a test kit from tfttestkits but I need to try getting this under control and getting the SWG operating if possible. Didn't realize that too much salt would require partially draining the pool. That would not be good.
    Thanks for the info.
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The granular stuff is usually much cheaper and can be bought at walmart, most home improvement stores, and many hardware stores. Pool calculator calculates weight and volume for you.
    Pool stores should have the aquacheck salt test strips.
    If you get the liquid stuff you will need about a gallon (128 ounces).
    Jul 2012
    Long Island, NY
    16
    Thanks, I will have her get whichever she can find. I will get the test strips when I get home tonight and see what the readings are.
    Really appreciate the help.
    Larry
    Intex Easy Set agp
    18'x48"
    5,500 gal
    Intex swg (cs8110)
    Setup 7/10/12
    Jul 2012
    Spokane, WA
    6
    Larry,
    Sounds like you may have a problem with your Intex SWG. I have the same model and it gave me the same error about 3 weeks after installing it. If you search in this forum or google the Code 91 error you will find it to be a pretty common problem with their units. Lukily you stopped where you were and did not throw in any more salt which is what a lot of people do and end up with very high salt levels and it still showing a Code 91. I am pretty sure I read that the unit is not supposed to give that error until it is below 2000ppm and we know there is no way you are close to that. I called Intex customer support which is of course in a foreign country and got the run around a bit but got them to send a replacement unit and cell. I did a lot of research on the error and there was no deffinitive answer on what the error comes from in regards to a faulty cell or unit. The customer support employee first tried to only send me a cell cell then changed to only a unit but I argued until they decided to send me both. It arrived pretty fast though, less than a week so that was good. Have not had any problems yet with the replacement besides it not generating enough chlorine to stay around 3-4ppm but I think that is a problem with not enough CYA as I only have 60 currently. Currently I have it set at 7 hours and book says 4-5.
    As far as the party I would just stick to the BBB method and add bleach to get ready for the party and make sure not to throw in any more salt, your pool will be crystal clear and ready to go in no time! Good Luck.
    20' X 4' Round AGP KD Pool - 8200 gal.
    1.5 Dynamo Pump with Pentair Sand Dollar Filter
    Intex CS8110 SWG
    Gulf Stream HE90 Heat Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by AGP_Spokane
    Cya should help, but why haven't you turned up the hours to get a higher FC level?
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    When my salt level drops too low and I get the 91 code it seems to take awhile for it to go away completely after adding salt. Seems the water needs to get good and mixed. Swimming works great for mixing it. It also seems the unit starts better when there's already a good level of FC. After I get to these specs I no longer get errors. Worth a try. Looks like your pool is new, if everything you try fails can you bring the SWG back to where you got it and tell them it's bad so you can get another?
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
  20. Back To Top    #20
    Jul 2012
    Spokane, WA
    6
    I hope the CYA will help, added some earlier this week so waiting till next week to test. I have slowly been rising the time and testing, started at 4 as per the manual and been at 7 last 2 weeks. 7 Hours had me consistenly at 1.5 ppm.
    Intex CS8110 SWG
