Results 1 to 7 of 7
Thread: Got my TF-100 and the results are in
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    and they are not great, although I suspect the 3" of rain we've had today (and 5" this past week) might be skewing the results. Our pool is barely two weeks old, so that might also be skewing some of the results. Anyway, here are the results
    FC: 1 (clearly low)
    pH: over 8 (high)
    TA: 60 (a little low)
    CH: 130 (seems awfully low)
    CYA: ~30 (still getting the feel for this test, but think this is a good result) - I'd expect the CYA level to be relatively low since the pool is new
    So let me take a stab at what I should do to correct the above (using the Pool Calculator as my guide). Firstly, I added 182 oz of 6% bleach to raise the FC from 1 to 6. Next, I added 53 oz of 31.45% acid to lower the pH. My next step is to re-test tomorrow, particularly pH, TA and CH. After I re-test pH, then I can decide if I need to add more HCl and then I can decide how to address the TA.
    The CH results don't seem right, but maybe they are for a new pool? CYA levels are perhaps a little low, but not too concerning.
    Also, the water is extremely clear right now, no cloudiness to speak of. I have been adding bleach every day based on strip test results, so the FC levels have been maintained. I am running the pump from 9 am to 7 pm right now.
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Re: Got my TF-100 and the results are in
    BTW, should I do the overnight chlorine loss test just to have one done or is that reserved for pools that have visible issues present (cloudiness, etc)?
    30,415
    1. Lower your pH to 7.4 or so.
    2. Get more chlorine in your pool....6ppm is fine
    3. Your CYA should be @ 50ppm or so. I would increase it to that
    4. New pools tend to be somewhat high in calcium....I am surprised your calcium is low, too. I suggest you ad enough to get to 200ppm and monitor it to see if it rises further over the next 60 days.
    How do you intend to chlorinate the pool?
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    I am using 6% bleach to chlorinate. I looked into the 10% chlorine at the hardware store and it's priced worse on a unit basis, so will buy the 182 oz jugs of 6% bleach. I can store 10-15 of those jugs fairly easily, so I should always have enough on hand.
    I am going to do another round of tests tonight and see if the results are consistent with yday's results. If so, then I will address the CYA and calcium accordingly. I will need to get both of those chemicals at the pool store, right?
    Thanks for the feedback.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Quote Originally Posted by AaronGo
    The CYA (stabilizer) and Calcium are available at Walmart, if that is more convenient. They will be in the section with Purple bottle tops, along with pH control products.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Thanks, that works. Considering they are going to be cheaper, I'll make time to get them at Walmart. I've got a few gallons of muriatic acid, so will burn through that first, but I know that is also sold at big box hardware stores.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Did another round of tests just now:
    FC: 2 (adding 149 oz of bleach to get to 6)
    pH: 8 (adding 32 oz of acid to get to 7.4)
    CH: 135 (consistent with yday's result, going to add 173 oz CaCl to get to 200)
    CYA: 35 (going to add 36 oz to get to 50)
    I am going to add the CaCl in three phases so I can test the next day after each phase. I am going to add the stabilizer in two phases. I will re-test the TA tmro after I add some acid tonight.
