Results 1 to 9 of 9
Thread: New pool owner
    Jul 2012
    San Antonio, Texas
    6
    New pool owner
    I really don't have a lot of knowledge on pools, but I have an intex 16x48. Haven't put it up yet. My question is, I was wanting to get the swg for it, but do I need to get a better pump than the one that comes with it? Will the intex swg and the pump that comes with the pool be enough?
    Next question, how long do you run the swg and pump? (I haven't bought the swg yet).
    Okay, another question, what is the difference between swg and the sand?
    Last question, if I put pavers down for the legs, can the paver be touching the edge of the pool?
    I promise last question, how easy is it really to put up? I know to have the ground level.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New pool owner
    Hi Chevytruckgrl!
    Welcome to TFP
    I will take a stab at a couple of your questions...
    Quote Originally Posted by Chevytruckgrl
    Check out this article: http://www.troublefreepool.com/pool-.../pump_run_time
    They are two different things. The SWG generates chlorine from the salt in the water. The sand is a filtering medium.
    Jul 2012
    San Antonio, Texas
    6
    Re: New pool owner
    Thank you for your help. I did read pool school, yes I did read some of it again. Question, going to put the pool up and get the swg this weekend. Do I have to put chlorine and all after the pool is full, or do I just add salt? I looked through pool school and didn't find the answer.
    I love this forum!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New pool owner
    I would manually dose with chlorine and add stabilizer (CYA) when the pool is full. You need to raise CYA to between 60 - 80 ppm and add liquid chlorine to keep FC in the 4-6 ppm range. Use the Pool Calculator to determine dosage amounts. Once the CYA is dissolved in your water, the SWG should be able to keep up with chlorine demand. Note that it will take about 5-7 days for CYA to register on a test. Wouldn't turn on the SWG until CYA hits 60 ppm.
    Of course, you will need a good test kit to accurately measure FC, CYA, pH, and other parameters. Click the Test Kit Comparison link in my sig for more info on test kits.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: New pool owner
    Salt also needs to be fully dissolved for at least 24 hours. Best to start up with 40ppm CYA in a sock as it fills and just squish it frequently and stir. By the time the pool is full, it could be nearly all squished out. Unlike bleach, it won't damage the pool if not fully mixed.
    I really like how you're her asking questions ahead of time. I hope you find this helpful.
    The following assumes you've got a proper test kit for you new pool. It assumes you desire a sparkling beautiful clear pool from the first moment you fill it. So you have your kit in hand. K?
    (side note: you can test your water at the tap if you want a head start on this)
    • [list:3ut2s9kl]First of all, get all the wrinkles out before you've got a few inches of water in the pool. It's far easier to do the less water there is. That's a hands and knees thing. And remember, no matter how perfect the floor is when you start, you will see wrinkles after it's full. It just is... (they're good at catching heavy debris actually).
      Before you get out of the pool, grab a sample.
      You can test your water for pH, TA, and CH right now. Go ahead and do it. Visit Pool Calculator. See if you might need to adjust any of those and plan ahead.
      As soon as your pool is half full, add half the chlorine (40ppm CYA = 7ppm maximum FC - use Pool Calculator for full volume of the pool) slowly and stir very well with a skimmer or just get in and thrash around wading. Your pump should be ready by now. When you have enough water to start the pump, add the rest of the chlorine and test the pH again just to be sure (if anything changed between half and full, it'll be pH). Some fill water is very high pH (mine is 8.2 sometimes), some is high alkalinity. If pH is between 7.0 and 7.8, leave it alone for now. Report back here with your test results and assumed CYA level.
      Did I mention that you're squishing that sock with CYA in it every now and again? It should be nearly gone by now unless your pool fills in less than 4 hours.
      No worries about chlorine, you added what you need. The world is good. Your pump is running, pool is clean, has no wrinkles yet, and sparkles.
      Time to add the salt. Using pool calculator, calculate from 0 to the recommended ppm for your pool. Broadcast the salt into the pool, and brush it around to dissolve.
      Now, test your pool for chlorine. If it's below the maximum, re-dose to maximum with bleach.
      We assume it's the end of the day now. Let the kids swim. You're good. Run the pump/filter full time. Go have a drink. Sleep. You made a pool. It's a clean, safe pool. You did good.
      You don't have to worry tomorrow morning. Kids can swim. Test if you like before the sun hits the pool. See if you lost much chlorine overnight. I bet you didn't lose much, if any. Leave the pool, or talk to us here about your pH, TA, and CH if you want to adjust those. Or wing it cuz you read pool school and know what to do. Some adjustments can wait if they're not wild crazy out of whack. Relax.
      End of the day, test your water. (not CYA, no reason to). Replace the chlorine you lost back to maximum with bleach, drink, sleep.
      Day two. Same as before. Let people swim.
      Put the rest of the CYA into a sock, and squish it frequently.
      Sometime after they're done and after the sun is off the pool, start the SWG and set it for 4 hours. If you're up 4 hours later, test the pool. You're looking for a result of 7-8ppm. If you're in that range, good. 4 hours is enough to generate a day's worth of chlorine for you. If not, add or reduce the SWG run time as needed and run another cycle right away. Test when SWG turns off. Rinse, and repeat. Determine how many hours your SWG needs to run to produce a day's worth of chlorine (2-4ppm on average, I go with 4ppm if I'm in a guessing mood).
      Once you know how many hours your SWG needs to run, you can let it go whenever. Apparently running the SWG during the day works as well.
    [/list:u:3ut2s9kl]
    SWG's should come with bleach startup directions so people would stop calling them reaking out that their SWG can't make enough chlorine.
    All this being said, the filter that comes with the pool is not good enough. I functioned ok with two of those babies running full time on one pool but I'm now converted to the sand filter and I love it. I haven't had to vacuum in days. Actually everything that was on the floor, is now gone. GONE! All I did was brush it up into suspension. This pool was uncovered all winter, with gallons of rain (this spring set a record for rain around here, check my location) and junk fallen into it up till two weeks ago when I officially opened. I freakin love this sand filter!
    I've run with the cartridge filters for years. A few without BBB, and two full seasons of BBB without a SWG. The number of cartridges I've cleaned since I hooked up the sand filter is... zero. And that's not because I don't have a cartridge filter on the pool, because I do. It runs my skimmer full time and it's skimming like a boss a week later without any cleaning. I'm totally running it till it stops skimming. Something I've seen in < 5 hours on a walmart cartridge. It's been nearly a week now. Still skimming like a badazz nary a leaf or anything falling to the floor of the pool.
    Right... so there you go. Level your pool. Level it 1000%. You'll be fine. And plan to upgrade the filter. If you can afford it, just do it. You can function without it, but I'll never say it can be done without a second pump/filter and lots of management. I did it. Can be done. Get two cheapo Intex pumps if you don't upgrade.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2012
    San Antonio, Texas
    6
    Re: New pool owner
    Out finishing the leveling, boy is it hot out (Texas). This is not an easy job, but well worth it. Pool to go up this evening or early morning. I'm so very excited! Didn't get the swg like I had planned this weekend, but that will come in time. I'm planning on getting a good test kept at Leslie's in the morning. Want to start out the right way. Will keep everyone posted. This is work, but it's so well worth it.
    Thank you all for your help.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: New pool owner
    I think everyone levels the pavers with the ground, so they don't push into the liner.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: New pool owner
    Make sure that you get the recommended test kit. I have read in past thread that Leslie's tends to sell you the wrong one.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Jul 2012
    San Antonio, Texas
    6
    Re: New pool owner
    Here is where we are on the pool. Set up the pool this morning. It took 2 of us about 45 minutes to set the pool up. Started filling the pool and I'll be dog if we were off on the leveling by about 5 inches. Thought we had it all done right. Put the level on the 2x4 and it all looked great. So, had to drain pool and re-level. Filling the pool as we speak. Looks good though. We are 1 square off in leveling and I'm okay with that. Not bad for my first pool.
