Results 1 to 7 of 7
Thread: Stonescapes color variation - will this go away??
    I recently had a full remodel done on my pool and went with Stonescapes mini pebble - Topics Blue.
    The pool finished filling last Saturday and i've been brushing it twice a day since then. There is still alot of color variation especially on the deep end walls and floor. Tuesday, while I was at work the plaster company came out and dumped in a bunch of acid. The only reason I know this is because test results went from TA of 80 to 0 and pH of 7.0 to off the charts low. Confirmed with PB when I saw results that's what they probably did. Anyway I am not happy with the finished product.
    See pictures below and ignore the green-ness. It looks perfectly blue in the daylight. My camera and the pool light just didn't agree, but the variation is very evident.
    Overall the surface is smooth and it appears to be a decent job aside from the splotchiness and variation. Do i need to wait longer? Am I being impatient or unrealistic with my expectations?
    Thanks for your advice.
    26,000 gallon IG Free Form
    StoneScapes Mini Pebble plaster (Tropics Blue)
    Pentair 1.25 HP WhisperFlow Pump
    Pentair FNS 48 DE Filter
    Hayward Heater
    Polaris 280 Cleaner & Booster Pump.
    Re: Stonescapes color variation - will this go away??
    One more pic
    Hayward Heater
    Qwaxalot's Avatar
    Jun 2012
    439
    Some variation in pebble finishes is normal. That said what I'm seeing in your pix seems excessive.
    Did the installers acid wash after installation?
    Oh yes, if there's no bypass on the heater, the acid they added is actively eating away your heater's heat exchanger
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Thanks for the feedback Qwaxalot. The PB agrees the variation is excessive and has the plaster contractor working on it. He mentioned a no drain acid wash but they haven't done that yet. Whatever they did this morning while I was at work improved the appearance some.
    I also shut off the pump to prevent heater damage.
    Hayward Heater
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I'm glad your PB agrees; that makes everything easier. It looks bad!
    Wanted to give an update to "close out" this issue for those who may be considering Stonescapes. The PB agreed the surface needed work and had the plasterer work on it over several days. They spot treated several areas and also kept the PH low. To my surprise what they did made the surface look fantastic. I don't have any pictures because it has been raining alot since then but take my word for it, I am now satisfied. Throughout the whole remodel I was always polite but firm and kept an open mind. We ended up with a beautiful pool. Thanks for the comments alone the way.
    Hayward Heater
    Oct 2009
    3,899
    Glad to hear it!
