Thread: Pool water has gotten cloudy
    My pool water started getting cloudy yesterday. Today it is even worse. My chlorine was a little low (I added bleach an hour ago), but that has never made it cloudy before. Does anyone have suggestions? I cleaned the cartridges a few weeks ago. I run the filter from 9a-7p.
    I had to go to the store to get more re-agent and the guy at Dolphin told me to shock it.
    FC = 3.5 (after adding bleach)
    CYA = 30
    pH = 7.6
    TA = 120
    Borates = 35
    Thanks.
    Kathyo in Texas
    21k gallon IG gunite w/ spa & waterfall; Waterway filter 817-0106; Polaris 280 cleaner
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool water has gotten cloudy
    Almost always, cloudy water most ofter indicates you have algae...especially cloudy water soon after adding bleach.
    You need to do the shocking process.
    Do you have values for CC and CH?
    38,235
    Did those tests results come from the pool store or your own kit?
    If your own, which kit?
    If the pool store, order yourself one of the recommended test kits as you will need it for the shock process (at least the FAS-DPD test).
    Thanks. I started the shock process as soon as I saw the responses. I have a Taylor K-2005 test kit and a FAS-DPT test. I also had the store test (since I was there to get some reagent).
    Kathyo in Texas
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Let us know how it goes, post numbers
