Thread: Help on the CC test
    Apr 2008
    Central California
    36
    Help on the CC test
    I'm converting from Baquacil to Chlorine - this topic http://www.troublefreepool.com/viewtopic.php?t=5012
    when I do the drop test for Chlorine I've been getting results somewhere between 12 and 15 FC (right now that's my target to get rid of the Baquagoo). I say somewhere between 12 and 15 because the water in the tube turns back to pink from clear....not really how sure how long it should stay "clear" to call it done (question "A")
    question "B" - I then work on the CC test. Add the drops to turn the test solution back to "pink" - although it turns dark red. I've not been able to add enough drops to get it back to clear and I know the number would be waaayyy too high - so question "B" - is the baquagoo interferring with the test and/or is this a function of the elevated levels of FC I'm targeting.
    question "C - is this something I shouldn't worry about until I get through the conversion?
    Mark A. Wolf
    vocation = engineer
    avocation = bass trombone
    homebrewing, swimming pool chemistry - all my home science experiments
    21000 gal gunite IG pool/spa; Hayward Swimclear 3020 cartridge filter, Hayward Northstar pumps (one filter, one waterfall), heater (not sure size), Hayward Navigator
    30,432
    Hi, Mark,
    Great pictures!
    I think the answer to question C is that the cc's don't matter for a few more days. Some better chemists than I will be along soon to help but I believe the Aquagoo has made the cc's test irrelevant until you clean it out some more.
    The answer to question a is that the endpoint of the test is the last drop that makes it turn clear. Almost always, it will very shortly return to pink but you can disregard that....once it clears, the test is complete.
    I have not done a conversion personally but "witnessed" several on this and another forum. It takes nerves of steel to watch your pool go thru this but you'll enjoy the rewards soon.
    You are good. Your CC level is very high, which is to be expected early in the conversion.
    Apr 2008
    Central California
    36
    thanks for the comments - I sort of figured those would be the answers, but it's always good for a second (or third) opinion
    Mark A. Wolf
    vocation = engineer
