Thread: Ball Valve Question
    Jun 2012
    Glen Burnie, MD
    38
    Ball Valve Question
    Brand new to the pool thing...
    I had two ball valves installed, one under the skimmer and then the other after the chlorinator. If they pump is turned off, do I need to close the valves? I wouldn't think so due to the water sitting in the tubes.. The only time I would think to close them is to clean out the filter...
    8000 Gallon 18' Round 52" Deep Morada Pool (Namco) DE Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Ball Valve Question
    Welcome to tfp, richhie6
    No need to close the valves (unless you have leaks and if you have those, you should fix them).
