Results 1 to 10 of 10
Thread: Attempting liner cutting mod of return this evening...
    Jul 2012
    Mountain House, CA
    62
    Mainly posting so I don't chicken out when it comes time to cut my liner, with my wife breathing down my neck "Honey, are you sure this is going to work and you aren't going to ruin the pool you just spent all week getting in perfect condition??"
    My issue is that my plunger valve tends to work its way off of the rubber inner sleeve on the return, after I upgraded from the tiny A cartridge type pump/filter that comes with the 15' Intex metal frame pool to the 2650 GPH sand filter.
    I am about to go on vacation and I'm scared that it will come off while I'm away and all my hard work will be ruined.
    I will document the process - win or lose - with lots of pictures. Stay tuned!
    10k gal IG w/ salt system, spa, gas heater, and auto cover.
    22,553
    Re: Attempting liner cutting mod of return this evening...
    We are waited with bated breath! Good luck!
    Jul 2012
    Mountain House, CA
    62
    Ok, it's done. And worked out 95%, and will probably work out 100% once I spend a little more time on it.
    Here's what I had to begin with. This is using the "Adaptor B" from the 2650 gph to attach to the rubber sleeve which comes installed on the pool.
    This connection was fairly flimsy and had twice worked its way off from the water pressure. Tightening it further only made it worse.
    This is the normal return which you'd use on a larger pool which comes with the proper sized holes for it.
    In my case, I had to cut the hole larger! Dun-dun-dunhh!
    I used the gasket as a pattern to trace to create the proper sized hole.
    I removed the existing connection, quickly slipped it on there, and replaced the valve. I got wet. Oh well.
    You can see here the wooden dowel which I had been using to brace the valve to keep it from popping off as easily. This was jammed in the sand below to keep the weight off the connection as a temp fix.
    Then I traced out the hole with a sharpie.
    Here's my bowl for sealing (mostly) the pool water out while I did surgery. There's my surgical tool.
    The next part went fast. My wife held the bowl on, muttering "oh gawd" (this is confidence building), and I quickly cut the hole, slipped on the new part, and connected it up to the valve as quickly as possible.
    It worked! No leaking!
    Well, on the outside, anyway. On the inside, water does squirt a bit out of the rim of the return. I guess it doesn't really harm anything, but I think if the water level was lower, and I could loosen it and reposition everything, it might not do that.
    In any case, it's a success. I never would have dreamed of attempting this without a lot of info from this forum, so many thanks!
    Oh and here's my byoo-tiful pool that was pea soup not 10 days ago:
    Adios for now!
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    Very nice!! See cutting your pool isn't as scary as it seemed
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    22,553
    we knew you could do it!
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Good work. I wonder why they make those with such a small inlet?
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Ahh wives, you have to love their supportive nature ahead of time and hindsight commentary:
    - your not going to screw it up are you?
    -......well, that's not the plan
    Sorry, couldn't resist.
    When I had to cut my skimmer opening, which is pretty straight forward, I was pretty nervous also.
    Great job! I have the Ultra Frame Intex pool but my plunger valves look the same. Was that going to 1 1/2" flex-hose? I think Intex only made one size of that valve and I'm about to replace my return also with a Hayward and have been trying to figure out if I'm going to have to do more surgery as well (already put a thru-wall skimmer in). Also, what size "eyeball" is on your return and is that one return working ok with the big pump? I have the 2650 also and my Intex return is fairly large. A little concerned with just the one smaller return but I want to get away from the Intex threads and have something standard on there.
    Intex Ultra Frame AGP 16'x48" 5,061 Gal with SWG 2500 GPH pump Cartridge filter
    Jul 2012
    Mountain House, CA
    62
    Quote Originally Posted by Glock
    Dunno, but when I look at the piece I cut out and the new diameter, it's a huge difference.
    I think I will also cut a hole for the intake side, just to reduce flow resistance and make that a rock solid connection as well.
    May 2011
    Clearwater, FL.
    446
    The bowl trick is cool, I need to come up with something to put in a Hayward puck light in the new pool, almost 13,000 and would lose a lot where I want to put the light in the wall, from digging a deep 6' center.
    I had very good success with the Hayward model through fitting with the seat and eyeball setup.
    Here's my post when I did it last year on my Intex. (it's been given to son to make way for the 21' I put in this year!)
    My posts start at the bottom of the first page and continue through the post.
    custom-pvc-pipe-adapter-for-intex-pools-t28971.html
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
