Thread: Reverse osmosis treatment in New Jersey
    Jul 2012
    Trenton, NJ
    7
    Hi Everyone,
    I have been trying to locate a company servicing NJ that does reverse osmosis treatment on pools, but as of now, I haven't had any luck. My CYA levels are higher than I want them to be and I'm looking for an option instead of a drain and refill. My CYA is around 100-110 and I want to get it down to around 40.
    If I can't get the RO treatment, I guess I'll do the drain/refill route, but wanted to avoid wasting all that water. Thanks for any recommendations.
    ~26,000 Gallon In-Ground Vinyl lined Pool
    Sand filter - Not sure on size of filter or pump
    Location - New Jersey
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Reverse osmosis treatment in New Jersey
    RO treatment is available primarily and maybe only in the southwestern US where calcium levels are high and water is scarce.
    Jul 2012
    Trenton, NJ
    7
    Thanks. That's what I figured. Guess I'll be doing a drain and refill.
