Results 1 to 8 of 8
Thread: Quick filter pressure release valve question...
    Jul 2012
    CA
    240
    Hello there, i have a issue with filter, maybe you can help out...
    The treads for the pressure release valve on top are stripped a little.
    I can get a small turn but if i tighten down it'll loose the 'bite'
    My worry is the pressure will shoot the valve possibly hurting some one or shooting off when im not home and draining pool.
    Im trying to think of it like metal threads, if stripped, just weld up, drill and tap.
    Would that be that be possible with some kind of jb weld or somthing similar?
    hey thanks for any help
    25k I/G ecostar ccplus Polaris plaster
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Quick filter pressure release valve question...
    Do you have a photo of the valve and where it's installed?
    -- Guy --
    22,553
    It might be possible but without knowing the make of the filter and exactly which part is stripped I can't recommend trying to repair it.
    Jul 2012
    CA
    240
    Herei it is... its a pent air filter.
    22,553
    And it's the filter body that's stripped?
    You may be able to epoxy it but I never recommend repairing a pressure vessel. You could drill out the hole and use a bulkhead fitting.
    30,432
    My bet is it's the black assembly that is stripped and that can simply be ordered as a separate item.
    Screw it in, screw in the gauge, screw in the relief screw and you're good to go.
    Jul 2012
    CA
    240
    Hot **** think that might do the trick, just have to figure out the thread pitch, might not have to drill if i can find right diameter, just file the remaining threads down.
    bulkhead fitting $4.99 vs. new filter top $170
    thanks again guys, knew this pace would be helpful.
    ps What do you prefer, teflon tape or those puddy sticks?
    22,553
    I prefer Teflon paste.
