Thread: Newbie Tests
    Jul 2012
    Brazoria, Texas
    24
    Newbie Tests
    If I did this right this is what I have:
    CYA 70
    FC 11.50 ppm 23 drops x 0.5
    CC 1.00 2 drops x 0.5
    TA 180 18 drops x 10
    PH 7.5
    Pool Calculator says add 1 quart 1 cup 1 oz of MAcid. Correct? Comments welcomed. I am leaving for a week, I leave my pump running 24/7, use autofill, well water, don't want a disaster when I come home and using the T-100. And it rained all day. Need assurance.
    Tx Gulf,IG installed 2011,FG 14X30 combopool/spa,SWG,AquaRiteTCell15, gal 10000,HaywardStarClearFilter Cartridge 4030/HaywardEcoStarVarspdPump/PoolMiserAutoDrain/Hayward H Series Heater/Stenner Classic Series Acid Injection/FiberStarsLights/Hayward Goldline ProLogic with AquaPod/TurboRoboticII/SequestTest if use Jack's stuff/TaylorK2006Test/K1766 ClorideTest/K1716 Iron Test/K-1730 Copper Test/K1766 Salt Test/Well Water
    38,235
    Re: Newbie Tests
    Adjusting the pH is not needed.
    If no-one is adding FC while you are gone, odds are you will need to go through the shock process when you get back.
    Actually since your CC is 1, you may need to shock already.
    Best bet is to cover the pool and put some pucks in it, but you CYA is already as bit high.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
