Thread: Chlorine Test
    Chlorine Test
    Hello Again,
    I have been maintaining my new to me pool for a month or two now and I am very satisfied and comfortable with the pool thanks to the knowledge I have gained from TFP forum and I thank you all for that knowledge. But I digress.
    I find that I only use the R-0870 DPD powder and the R-0871 drops to daily check my chlorine. I never use the the yellow capped R-0003 drops to check my chlorine. Is the DPD test more accurate than the R-0003 test? It certainly is easier for me to read the R-870/R-871 test.
    Many Thanks,
    Russ Stevenson
    10k in ground plaster
    Build date around 1980
    1.0 HP pump, Baker Hydropak Skimmer
    38,298
    Re: Chlorine Test
    The OTO (yellow) test is fool proof on determining if there is 0 chlorine in the pool (clear) ... or a LOT of chlorine in the pool (yellow to orange to brown).
    If your required FC levels are low enough, you can get by with the OTO test on a daily basis and use the FAS-DPD test less often to get specific numbers.
    There is nothing wrong with always using the FAS-DPD test as it is much more accurate ... other than running out of reagents
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Chlorine Test
    Quote Originally Posted by russ.stevenson
    The R-0870 powder combined with the R-0871 drops test FC. After recording the FC, the R-0003 is added to the R-0870/R-0871 solution to test for Combined Chloramines (CC). If the solution remains clear, you have no CCs (this is good). If the solution turns pink, add R-0871 to the solution, counting and swirling between each drop. Once the solution returns clear, multiply the added drops times .5 again - this is your CC. The amount of CC is a determining factor in whether to shock.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Chlorine Test
    You should be using the R-0003 to test for Total Chlorine, after you test for Free Chlorine with R-0870 and R-0871. After you are done testing by dropping R-0871 in and the water is clear again, put 5 drops of R-0003 in the same sample. If it turns pink, then you drop R-0871 in again drop by drop and count till it turns clear again.
    Take the result of the R-0870 and R-0871 reading and add the drops you used in the second phase after using R-0003. This is your Total Chlorine (TC) result.
    So, let's say you used 8 drops of R-0871 for a result of 4ppm Free Chlorine first, then added R-0003 and it turned pink. Let's say it took 2 drops to turn back to clear. Your results would be as follows.
    FC = 4ppm
    TC = 5ppm
    CC = 1ppm
    In this case, since CC is over .5ppm, you would need to begin the shocking process.
    If the sample doesn't turn pink after adding R-0003, your CC result is 0ppm.
    The reagent you would want to use for the OTO test is found in the blue box that is in your TF100, I think it's R-0450 or something (hard to read the label on the image). But it isn't R-0003, that won't work for the OTO.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    38,298
    Re: Chlorine Test
    Thanks for clarifying ... obviously I read the original post wrong
