Thread: New liner, anything special I need to do to BBB it?
    Greetings. My new liner was put in today. I have 2 water hoses in it running wide open, and it looks like I have barely dripped any into it. Can't wait to see that water bill!
    My question is, once filled up and opened, do I need to do anything special as far as BBB since it's a new liner and new water? Should I just treat it as I always did and take my levels to normal?
    I need to get the water fixed, the solar cover on, and hopefully swimming next weekend!
    TIA.
    18x36 IG oval w/vinyl liner, 21k gallon, sand filter, Aquabot cleaner
    Just balance your water to the same parameters you are used to... No need to do anything special!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
