Results 1 to 11 of 11
Thread: abg filter
    abg filter
    We realize are filter is too small. Also the company that installed it made is so every pipe drips water. They will not fix it. Nor do we have any cut off valves. So my husband and I decided to buy a new larger filter and add some cut off valves. Who do we call for that? I do not want to call the company who installed the pool. The 3 pool stores around us say since they didn't install the pool they can't help us. We even called a plumber but he of course said that was a pool issue not a plumbing issue. My husband is not a Mr fix it, so installing it ourselfs may be a bit much for me. I love to build but I've never messed with pipes. We have an ABG 15x30. Right now we have sand and are having nothing but trouble from it. So what do your recomend for us, and who do I call to install it?
    AG 15x30 4 ft deep 12000 gal.
    Aqua Star 100lbs Sand Filter model fs019
    Installed june 2012
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: abg filter
    First of all, what is this "nothing but trouble" you speak of?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Re: abg filter
    Look in the phone book for pool service companies. In most areas there are many of them. Not all of them will want to take on a small plumbing job, but a fair number should be interested.
    Re: abg filter
    nothingbut trouble includes, I have to run my filter 24 hours a day to have any effect. The skimmer basket keeps getting stuck causing the filter to run dry. When this happens the filter will not pick any psi up. It will stay at 0. I t will have a slow flow with dirty water coming out. I will have to let the filter sit for seveal hours before it will run. I belive the company who put the pool together put way to much caulk around the skimmer. I tried peeling some away but I am afraid I will pull to much. I need to back wash 2-3 times a week.
    Installed june 2012
    Jul 2011
    844
    Re: abg filter
    Ok. Forget the plumbing issues for a minute and let's see if your fiter has a problem. If you are having to backwash that often, it's because your filter is doing its job. There may be nothing wrong with the filter. If it's building up pressure, then it's getting dirty due to stuff in your pool water. You may have algae. How does your water look. Is it clear?
    Bestway SWG
    Re: abg filter
    Yes I shock last week.
    My stats this am are
    Fc 7
    cc0
    cya 40
    Ta 90
    Ch 120
    PH 7.3
    water is good
    Installed june 2012
    Jul 2007
    Hillsborough, NC
    520
    Re: abg filter
    Can you post pictures of the existing setup? We can help with how to do the work yourselves to add the shut offs and replace the filter. It isn't that difficult to do. You will need to plug the skimmer and return so the water doesn't leak out of the pool while you are working. What do you mean "filter basket keeps getting stuck?"
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Re: abg filter
    Here are some of the photos to my set up.
    Installed june 2012
    Re: abg filter
    Here is the second half. I tired to show where the filter nd hoses are leaking. As well as where the skimmer is getting stuck because of too much caulk. But I could be wrong. What do you think?
    Edited to add a phot of the leaky filter
    Installed june 2012
    30,402
    Re: abg filter
    I would take a safety razor blade and cut away that excess caulk. That is a poor workmanship but you know that already.
    Just shut off the pump and take your time with the safety razor blade. Don't try to "scrape" the putty off with the blade but actually cut it by using lateral movement like you would with a knife.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: abg filter
    Wow, this was just installed last month and they won't fix the relatively small issues? That's kinda sad. You don't show a picture of your pump. When the pump goes dry the quickest way to get it to run is to release the vacuum to let the water back in. There's usually a knob that you can turn to let this happen. Some setups you would loosen the pump cover just enough to refill the basket with water. Hard to tell how yours is without a picture of it. Make sure the pump is off when you do this. You can add a bit of DE to make the sand filter better.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
