Thread: Hard Water
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Hard Water
    I know it is suggested that if you check your water and it is "hard" you should do a partial drain and refill it. But what if your water is very hard coming from the tap? We have hard water here (city water) so wondered if there was a way to get it "softer".
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    30,426
    Re: Hard Water
    Hard water is high in calcium....what does your CH test tell you if you test the tap water?
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Re: Hard Water
    I will have to check it. I know this spring when I tested the water in the pool prior to adding any chemicals it was high but it was straight from the tap, but I don't remember numbers.
    Deck built in 2011
