Thread: Can i lower PH to remove stains and then add pink stuff to i
    Oct 2010
    michigan
    284
    Can i lower PH to remove stains and then add pink stuff to it
    I already did a AA treatment 3 weeks ago, the stains came back a week ago, I used metal free, was told by some of you guys thats not the good stuff and use the pink stuff by jacks magic.
    can i just lower my PH to 6.8 using muratic acid to get the stains to lift then add the pink stuff to the pool?
    I would leave the pool filter off since i have a heater, but i do have a cleaning robot that circulates the water pretty good.
    opinions and advice? thanks
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Re: Can i lower PH to remove stains and then add pink stuff
    Only lowering the PH is unlikely to remove the stains, unless they are very very recent, as in today or yesterday.
    Oct 2010
    michigan
    284
    Looks like i'm lucky, had PH at about 6.6-6.8 and the stains have reduced to not visible by my wife, but i can still barely see them, but more than happy if it stays that way thru the year till i close the pool. then i can do a AA at closing and drain 1/3 of the water.
    dumped 2 bottles of pink stuff, (20,000) gallons, i have 15,000
    right now slowly raising the TA/PH back into range.
    hopefully the stains don't come back.
    ofcourse the pool filter isn't running, have the robot circulating the water nicely.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Be certain to maintain the pink stuff weekly because that phosphonic acid will break down continually and then the stains (if iron anyway) will come right back as the ph rises.
    Also note that in my experience when the pink stuff is active, it will help hold the ph down (eg. not as fast a rise) but will also use a little more chlorine than usual for a few days, so don't be surprised, for example, if you are suddenly using 3 ppm of Chl a day instead of 2 ppm.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Oct 2010
    michigan
    284
    thanks for the info swampwoman
