Thread: Pool heater - suggestions??
    We are having our pool installed next week. We didn't get a heater yet but are thinking we may want one. The place we bought the pool sells Hayward 150FDN (we need 150,000 btu) natural gas heater. Of the reviews I've seen for Hayward, they aren't the best but I don't see any for this exact one. Any suggestions? We live in IL so it would surely extend our pool season. Also - if we end up with a SWG down the road, are there heaters better for working with salt water?
    38,548
    Re: Pool heater - suggestions??
    There are some heaters that use a different metal in the exchanger that is less prone to issues with the SWG ... of course I can not think of them right now. Hopefully someone else will be along with more information.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Heaters with Cupronickel or Titanium heat exchangers claim to be well suited for Salt Water Pools. These heaters may use some Bronze parts as well, like for end caps on the heat exchanger.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    You could buy a gas heater with the cupronickel heat exchanger but you can also ruin it as well if you do not maintain your pools chemicals properly. In a uncared for pool, a cupronickel heat exchanger will last a little longer before it leaks. As for reviews, everyone has something bad to say about every product out there. As long as you take care of your chemicals correctly and even remove the heater at the end of the season, guessing you are getting an above ground pool since you're in IL, then it could last a long time.
    Titanium heat exchangers are mostly found in heat pumps.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
