Results 1 to 9 of 9
Thread: Help me identify this valve
    I believe this is a check valve... and it has a cracked cover causing a slow leak. I'd like to find a rebuild kit, but I'm not sure who made it. Unfortunately, the PB put the plumbing for this valve under concrete decking leaving no easy way to replace the entire unit. I just have a 6" access cover to work with.
    Anyone know the manufacturer?
    [attachment=0:3stdz2m3]2012-06-30_16-58-04_40.jpg[/attachment:3stdz2m3]
    Thanks!
    Shelley
    Denver, CO
    38,274
    Re: Help me identify this valve
    What is the other word besides Lock?
    Have you taken the screws out to see what the inside looks like?
    The top kind of looks like the Jandy/Pentair check valves, but I have never see the twist thing/gear on the top.
    I think the other word is "unlock". This happens to be my friends pool and I'll need to ask what it says to be certain... but pretty sure it's "unlock". If no one recognizes this thing taking it apart would be our next step.
    Thanks.
    Shelley
    Denver, CO
    22,548
    I did some searching and haven't found anything. I think your best bet it to take the top off it and see how the inside is designed. It may be a simple on/off valve.
    Here is picture of the inside. It turns out it's a regular 3-way valve, but with no identifying markings anywhere. How is a guy supposed to get parts for this POS? Perhaps this may help someone recognize the thing. You can see on the ground a jandy valve i brought over to see if it would fit. It doesn't.
    [attachment=0:2ne4nnoj]20120713_091935.jpg[/attachment:2ne4nnoj]
    Shelley
    Denver, CO
    Looks like an old waterway valve. Look on the part in your hand and see if there are any numbers.
    I think I may have found it for you.
    http://www.aqua-man.com/schematic.asp?kc=S1787&s=full
    You are a wonderful human being! Thank you.
    Quote Originally Posted by Confused
    Shelley
    Denver, CO
    Glad I could help you. You could contact Pentair and see if you can change the upper part of the valve with one of their newer models.
