Results 1 to 7 of 7
Thread: New vinyl replacement/How to balance water
    Repalcing vinyl. Need to know the steps to balance water. Do I need to bring to shock level? CYA, PH, TA, FC what do I work on first? Thanks
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Feb 2012
    Phoenix, AZ
    728
    Re: New vinyl replacement/How to balance water
    When you get the new liner in and fill the pool, you should measure and post all of your levels. The correct course of action will be based on that
    thanks I'll do that.
    Central, VA
    Been trying to get dirt out from the new fill. Pump up and running here are my numbers
    FC 0
    PH 0 little color
    TA 120
    CH 80
    CYA 0
    Ok what do I do first?
    Central, VA
    22,553
    pH surely isn't zero!
    Add 2 ppm fc now and adjust the pH if it needs it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    koliver13 please keep your posts on your water chemistry in your other thread. Thanks.
    Ok will do thanks for your help
    Central, VA
