Thread: concrete block pool
    concrete block pool
    Hello! In my quest to obtain a pool, I've come across this concrete block pool idea. Now, I've read the majority of the 38 page related thread. Needless to say, I've got some questions.
    1) Where does one obtain pool parts? (skimmer, drain, ect...ect..)
    2) What can one use to seal the inside walls. - I've seen this sani-tread stuff. Does anyone have any experience with this stuff?
    3) Can you use something to enable a little more creativity with the inside walls? I was thinking about rounding the corners, smoothing out coves or steps; basically rounding out things in general with either plaster or something along the lines of a surface bonding cement. I've read that the surface bonding cement should stop water, but figured on either putting in a liner or coating with the sani-tread.
    Well, that's a start for now. I don't want to make the post too question heavy. I'll ask more as things progress.
    Thanks!
    Re: concrete block pool
    Duraleigh is the resident expert. I'm sure he can answer all of you questions and then some. See his build here:
    an-unusual-pool-build-t10597.html
    May 2011
    Orange County, CA
    696
    To answer question #1:
    You can obviously source parts from a local provider (like Leslies), but it's probably cheaper to buy them from online dealers (e.g. A1poolparts.com, aquasupercenter.com, poolsupplyworld.com, h2opoolproducts.com, inyopools.com, etc). I'd suggesting thinking about what you need and then checking the products out online. All of the major vendors (Pentair, Zodiac/Jandy, Hayward, Raypack, etc) have product catalogs and manuals online. You can also get suggestions here, as many of us have experience with the latest stuff out there. Sounds like a fun project!
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Thanks for the replies. That build of Duraleigh's is pretty sweet. I'd have a hard time explaining to my wife why we need a pool bigger than my wood shop. Come to think of it, she may very well like the idea. I just may start out with a smaller project to test my ideas. I'm thinking a cordwood hot tub perhaps. Time will tell. In the mean time, I'll keep researching. I think I'll start with those suppliers mentioned. Thanks again!
