Thread: Amperage of 1 hp pool pump?
    Jun 2008
    Marana, AZ
    347
    Does anyone know approximately how many amps a 1 hp pool pump draws? Specifically the pump is a single speed, Hayward Power-Flo Matrix.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Amperage of 1 hp pool pump?
    should be a sticker on the side telling you current draw. If current draw is not posted it should at least say wattage wich using voltage divided by watt will give you amps.
    in canada anyways the sticker has to be on the motor to get the ULC/CSA stamp. I'm sure it's the same on your side of the border.. but you should be fine with 14AWG wire.. as I doubt it will draw more than 15 amps.. wich is a typical household circuit.
    just guessing it's probly around 1-2 amps
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    22,543
    Since it's an aboveground pool pump it's an uprated model and probably draws in the neighborhood of 10 to 12 amps at 120 volts. Depending on your plumbing it may draw less.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I've seen 11 and 12A given as the numbers for that pump for max amps. The actual draw may be less, depending on the plumbing and filter.
    Jul 2007
    Hillsborough, NC
    521
    If you are adding a circuit for the pump, I would pull 12 gauge wire for a 20A circuit. That gives power for the pump as well as lights and outlets for radio, etc. Whatever circuit you put it on must be GFI protected, either via breaker or a receptacle.
    The 1 HP Power Flo Matrix PN SPX1510Z1XE is rated for 12 amps.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
