Results 1 to 8 of 8
Thread: Auto covers - maintenance nightmare or maintenance panacea
    Jul 2012
    Bel Air, MD
    52
    I have a read a lot about auto covers and they seem to offer a lot of benefits. They help to heat the pool, they reduce the need for chemicals, they provide a ton of safety and they help to keep leaves and other things out.
    With that said, I have heard horror stories about the costs to not only install them, but also to keep them running. At a minimum it will be multiple thousands of dollars for the install. I have read that it also may cost a thousand or so for annual maintenance.
    I am trying to get an understanding to see the real story and answer two questions:
    1) what model/manufacturer do you have and how much have you had to pay after the initial install to keep it running?
    2) are there things that seem to affect the maintenance cost more than others (width, length, SWG vs chlorine, manufacturer, etc...)
    Thanks a lot.
    Jan 2012
    'burbs of Augusta, Georgia
    7,252
    Re: Auto covers - maintenance nightmare or maintenance panac
    Mine has cost nothing to maintain, and not had one problem since putting it on last fall.
    These are the folks that installed mine-http://www.pcs-se.com/
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    I have the Aquamatic. I've had it about 10 months now. So far it has cost zero dollars since the initial install. I'm having a little trouble adjusting the "skew", so far I have not managed to do better than about 3 inches, but the manual says that's within tolerance.
    Even if there are some costs down the road, I'm very happy I chose to get the autocover. It helps manage the water chemistry, temperature, keeps debris out, and there's alot of "peace of mind" knowing that kids and critters can't easily sneek into the pool.
    Don
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    Nov 2011
    Moberly,MO
    1,010
    You shouldn't have alot of yearly expenses. You should use a good non solvent cleaner about once a year and hand wash the cover. The only other advice pick a lighter color than a dark one as the uv won't affect it as quickly.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jul 2012
    Bel Air, MD
    52
    No one else has an opinion? Ideally someone who has had one for at least a few seasons can weigh in.
    Nov 2011
    Moberly,MO
    1,010
    Go with a lighter color, the darker ones will give you more heat transfer but the sun eats the vinyl a little quicker. When you decide on a builder ask them how much a replacement cover would cost so you can prepare for the eventual cost.
    I've had my pool for 11 years. My cover lasted 10 years with no problems other then a broken cord which was fixed at no cost. It did however rip due to an over load of snow and ice during a bad winter. It ripped at the spot where it had worn through after 10 years. Insurance covered the expense of a replacement, which was about $3400.00 It does seem to get "off kilter" by a bit but installer will come out and adjust. The initial cost (8,000.00 or so) did seem like alot but what it saved me in chemicals (before BBB) and peace of mind was worth it. When we built our pool, our children were under 5 years old - the cover was one thing I wouldn't have done any other way. I've had my replacement for a year with no problems.
    Kris
    In ground 26,000 gal. 16x36 Avg depth-6'
    sand filter used 24/7
    auto cover
    Elgin/Illinois
    Jan 2012
    7,252
    yeah, that's how I feel about the cover too- peace of mind worth every dollar! We've heard of multiple young children drowning this summer alone. Each time I hear of one it just confirms to me that this was one expense worth scrimping for.
