Thread: in floor pop filter system not working
    I recently moved into a home with a pool that is 3 years old. The in floor pop ups do not pop up. The pressure is very high but still nothing. is there a owners manual or anything i can get to figure out how the system works and how to fix it?
    thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    It sounds like they are stuck closed. Most popups have a way you can remove them to clean and fix but you will probably need to know the manufacture and get a manual to find out. Otherwise, you could take a picture of one of the heads and see if anyone on the forum recognizes the make.
    Mark
    Mar 2008
    Maryland
    56
    Yeah definitely need to know who makes it so you can get the right tool to remove the pop ups and see if they are stuck. do you have wall returns as well as the infloor cleaner? If so and there is a valve to shut off the wall returns you could try that to see if the pressure forces any of them up but you need to watch your filter pressure to make sure it doesnt get too high.
    JoshU's Avatar
    New Orleans, LA
    543
    The three most common systems are made by Polaris (Caretaker), Paramount and A&A.
    - Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
