Thread: Where to put the LED lights?
    We are getting closer to starting construction. Pool is a 50 x 22 freeform. Right now there are two Intellibrites planned, one is in one end and another on the side (not facing the house). My question is: what are the Intellibrites like to swim towards when they are lit? Is it like swimming towards an oncoming train like an old style light? If I move the one out of the end, I think I will need 3 lights.
    Trying to control the hemorrhaging of the budget with all of the little extras, but if I need a third light....hopefully this will be the last little addition
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Aug 2010
    Maryland
    13
    Re: Where to put the LED lights?
    We Have 1 intellibrite at the center of the deep end Of our 20 x 40 pool rectangular pool. We should have also put one in the side of the shallow end Because the shallow end does not light up as bright. The costs of the build were mounting and my husband did not think it was worth the expense at the time though now he sees that the rep at the intellibrite company was right (imagine that, LOL). If I were you I would call the intellibrite customer service line and ask their advice. My pool builder also only recommended one light and they were wrong but they admitted they only see the finished product in the daytime which I thought was a lame excuse.
    Any way light is not like swimming into trainlight as water diffuses it. We usually use the colored lights anyway which are less harsh. I love mine and when liner is replaced will add another.
    30,000 gal 20x 40 inground vinyl, 3.5 to 8.5 ft deep, intellichlor SWG, pentair 48 sq ft vertical grid DE filter, 1 hp pentair pump+ booster pump for kreepy krawly pool vac, sun ledge, diving board, intellibrite LED pool light, tf100 test kit
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Two should be fine for your pool.
    Try to get them facing each other along each width end of your pool while not facing the house (as you stated)
    I could not do this exactly as stated above on my refurb and I still have plenty of light (18x 36 rectangle with stairs)
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    With a pool of that size (ie >45 x 20 or so), I think you can't go wrong with additional lights. My question is, if you are going to use 3, would it be best to place all 3 along a long side (facing away from the house) or put one at each of the ends facing each other and another in the middle of the long side perpendicular to the other two? The Pentair LEDs can be adjusted for wide or narrow angle... would this intersecting set up give the most even coverage? Otherwise if all 3 are on the same long side facing the same direction away from the house to the other long side, it seems ot me there would be a triangle between each light that would get little coverage.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
