Thread: Conflicting schooling
    cood60's Avatar
    Jan 2012
    Virginia Beach
    82
    I found a contradiction in school rules and just wanted to make sure I am doing the right thing with the water balance
    The Pool School section on the relationship between Cl and CYA (chart and all) says to drain pool water if CYA gets too high...above 80.
    The Water balance for SWG section says the biggest mistake SWG Vinyl pool owners make is to have too little CYA, ie keep it at 80
    Seems conflicting??
    Cush Dobbs
    22'x40' IG, Freeform, 26K gal, Vinyl liner pool(2011), three returns plus two step jets, one slide, two skimmers, two LED lights, Stamped Concrete with Aqua PL-Plus Automation panel, Pentair Intelliflo VS, Hayward Pro Series High Rate Sand Filter 500lb, Hayward Turbo Cell T-Cell 15 (SWG) , Dolphin Robotic Pool Vac, Hayward Heat Pump.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Conflicting schooling
    70-80 CYA for SWCG is typical due to the constant level of chlorine being generated.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Not conflicting at all drain when above 80 ie 90 and higher do a drain. Maintain at 80 not above for swg
    24' 52" Above Ground
    BBB
    LOVE TFP
    TF Test kits, Pool School, Pool Calculator
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    SWG has slightly different rules, seems they can get away with slightly less chlorine levels but prefer higher CYA because it takes time to generate the chlorine. With that said, I've found that areas like mine (not super hot and only partial sun) can get away with lower CYA. Much warmer where you live.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Bear in mind that CYA requirements can also vary by location, and some of the things here are suggestions that must be tailored to an individual pool. It's a balancing act - when your CYA gets too high, you will have trouble maintaining a high enough chlorine level to be effective. And if it's too low, it'll be hard to not lose your FC during the day.
