Thread: Where do I install a shutoff valve after the skimmer?
    Jul 2011
    Bedford, NH
    67
    I have a 15' round AGP with a new-to-me Waterways cartridge filter. Right now, the hose runs right from my skimmer box into my Hayward pump, then directly into the filter, then out to a single return. There are no shutoff valves anywhere, so when I need to clean the cartridge or do anything with the pump or filter I must disconnect the skimmer box hose at the pump and hold it above the water line. Obviously it'd be much easier to have a valve somewhere. But being new to this setup and unable to find a picture of a shutoff valve, I'm not sure what to do.
    FWIW, all of my lines are flexible tubing, connecting using hose clamps.
    18' round above ground, vinyl liner, 48" deep (flat), Confer Step1 steps. Approximately 7600 gallons. Waterways/Proline FC075 cartridge filter. 75GPM (71 minute complete cycle), 75 sq ft filtration area.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: Where do I install a shutoff valve after the skimmer?
    I purchased a pvc ball value and small piece of pvc pipe. I had an extra flexible hose. I cut the piece of pvc in half, glue the pieces into the ball value. I then clamped each hose to each piece of pvc. So that I have skimmer-hose-pvc piece-ball value-pvc piece-hose-pump. I can post pic tomorrow.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Jul 2007
    Hillsborough, NC
    515
    Anywhere between the filter and the return is fine. Here's my setup. I have ball valves both before the pump and after the filter. I also have unions on the pump. This winter I will add unions on the filter side as well.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Jul 2011
    Bedford, NH
    67
    Thanks. I should have read more first...because now I'm going to build a small concrete base and hard plumb my filter and pump. Should be easy then!
