Thread: Wahoo! TF100 kit arrived. Now for some real numbers...
    Aug 2011
    Central New Jersey
    20
    My TF100 kit arrived today.
    TC was > 5 (off the scale, maybe around 7 if I had to guess)
    Ph = 7.2
    CYA = 20 (the dot disappeared around 20)
    CH = 120
    TA = 100
    Almost there. I need to bump the CH up because it is a plaster pool. The Ph could use a little boost too.
    My CYA was zero when I opened last Thursday. I let a sock of 4 lbs. CYA granules dissolve on Friday, so, it has only been 3 days. I'm going to leave it alone and see if it comes up over the next few days (I'll let the trichlor pucks in the in-line chlorinator bring it up over the next few days then shut it down when it gets to around 40).
    The water is nice and clear and 75 deg. F.
    Damian
    29k gal. In-Ground Plaster Pool (Freeform), Hayward Pro Grid DE4820 (48 sq ft), Hayward SuperPump II (1 hp), In-Line CMP chlorinator
    Feb 2008
    Denton, TX
    5,061
    Re: Wahoo! TF100 kit arrived. Now for some real numbers...
    Glad you got your TF-100. The great thing about having it is that you never have to guess about your chlorine. It reads up to 50 ppm so you should know exactly what your FC is, even if it is over 5. Were you using the FAS-DPD test? That is the one where you add the powder and cont the drops until the pink goes away.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    >5 FC tells me you used the color block test.
    Use the dedicated cylinder, the R-0870 powder, and the R-0871 reagent. Then you'll know what FC and CC are. And you can test yourself to see how good you are at matching shades of yellow. Or not.
    May 2011
    Clearwater, FL.
    446
    Hi DPawlu and welcome to TFP!
    4 lbs of CYA doesn't seem very much for a 29,000 gal pool!
    Pool calculator shows me 9 1/2 lbs to get to 40ppm from 0.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Aug 2011
    Central New Jersey
    20
    Yes, I used the block test. I just ran the FAS-DPD test and came up with:
    FC = 13.5 (!)
    CC = 0.5
    Ouch! I guess it was a little more greater than 7 than I thought. I can let that level come down over the next few days.
    When I added the 5 drops of R-0003 it turned an ever-so-slight shade of pink and 1 more drop of R-0871 cleared it up again, so that makes the CC = 0.5
    There are some leaves, twigs, and some dead bugs on the bottom, but not that many. Should I worry about a CC of 0.5?
    Damian
    Aug 2011
    Central New Jersey
    20
    Quote Originally Posted by supertune
    I went light on the CYA. I was thinking the trichlor in the chlorinator would bring it up some more. Is my thinking correct?
    Note: I am only newly freed from relying on the pool store and thinking for myself.
    Damian
