Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: New pool owner...bought house with in ground fiberglass pool
    Jul 2012
    Herndon, VA
    419
    Previous owner was using tri chlor tabs in an automatic dispenser....and was using chlor brite to shock.
    I've had water tested using a computerized system, and my results are:
    Free chlorine: .15 ppm
    Total Chlorine: 1.63 ppm
    Combined Chlorine: 1.48 ppm
    ph: 6.9
    Hardness: 119 ppm
    Alkalinity: 85 ppm
    Cyanuric Acid: 250 ppm
    Copper: 1.6 ppm
    Iron: .29 ppm
    Upon reading info from pool school, I've realized that the previous owner has been adding CYA because he used trichlor tabs and chlor brite to shock....thus increasing CYA to these ridiculous levels.
    I know I'm not supposed to drain my entire fiberglass pool, or even go below the inlets when I drain, so I've started draining a couple of inches at a time and replacing water to mid skimmer level daily.
    I just added about 1 and 1/4 gallons of 6% clorox.
    Does that sound right? What should I do?
    Thanks for your help!
    Pool newb.
    P.S.: We closed on our "new to us house" on 6/28. Went for a swim that night that we closed....moved in on 6/30. Being a pool newb, I didn't realize the importance of monitoring the pool daily, so I didn't look in the automatic dispenser until about 7/4, and noticed the tabs were completely dissolved. I tested with strips on 7/5, and saw the FC levels were practically non existent, as they still are. By 7/9, both my wife and I have developed ear infections. I don't want to get back in the pool until I know it's safe, especially since we have our 9 month old swimming with us since we moved in.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Feb 2008
    Denton, TX
    5,061
    Re: New pool owner...bought house with in ground fiberglass
    Welcome to TFP!
    First off, you need to order you a good test kit that has a FAS-DPD chlorine test. The TF-100 at tftestkits.net is the best value out there.
    Good on you for reading Pool School. Keep reading it. It's good that you recognize that your CYA is way too high. Draining it a little at a time takes a while, but it is safer to do than draining all at once and risking folating your pool shell. You want it down around 30 or 40.
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by 257WbyMag
    Welcome to TFP!
    Thanks for the reply.
    I've got Aquachek Select test strips at the moment.....and they actually seem pretty accurate according to the computerized readings I've been getting at the local pool store.
    Caveat being: I went to one pool store yesterday, the computerized printout showed CYA level of 139 ppm. He recommended 2 pounds of shock, but didn't ask me what shock I was using, and me not realizing shock was a verb, and not a product (per pool school) used the chlor brite the former home owner left me. Later yesterday, I went to a different pool store to see what the results were. That store used a non computerized test (Leslie's pools)....and the result for CYA was 60 ppm....more than half off what the other pool store told me. When I asked how there could be such a discrepancy, another employee tested and said, "yeah...it looks more like 100".
    Today, I went back to the original, computerized test store (Anthony & Sylvan), and the employee there (different that yesterday) told me that my CYA levels were actually more around 250 (which corresponds to what the Aquachek test strips were showing me), but he manually changed it in the computer to just below 150 ppm, because if he didn't, the computer would suggest as the course of action a complete drain of the pool.
    So basically, pool store employees will more than likely not even tell you about your high CYA levels, or completely lie to you, to ensure that they sell product and still have a job???
    May 2011
    Clearwater, FL.
    446
    Hi GuinnessPhish and welcome to TFP!
    Without another thought...get a TF-100 kit on order, you'll need it to test chlorine levels correctly and get your pool healthy and trouble free!
    Keep reading here and in Pool School to learn all you can.
    It seem hard at first but becomes very simple once you practice it.
    Once you have your test kit run a full set of test and come back and post here and we can help and advise you to get you going on the right path.
    For me...my pool using this system has helped my grandkids (raising all 3) never get ear infections now that they swim in my perfect TFP pool.
    Always had ear infections before I found this place! (I was pool stored!)
    Don't put any trust in pool store testing especially a computerized one, who knows when it was last calibrated?
    Test strips, no good either. Throw them in the trash.
    Your better off with a drop based kit from wally world until you get the TF-100 or Taylor K-2006 FAS-DPD kits
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by supertune
    Chuck
    Just to be sure....
    the tf-100 kit is all i need? None of the additional options are necessary?
    Just get this?: http://tftestkits.net/TF-100-Test-Kit-p4.html
    The speed-stir is a wonderful addition - optional, but totally worth the money in my opinion. I'll let others chime in on if you need any add-ons in terms of reagents, etc.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    TF-100 is what I have. I've needed to get more CYA re-agent and a couple yellow refills but that's after a few years of use (forget what that one is called, it's the basic chlorine test). It's a good kit, you probably want extra CYA test re-agent. It will take you a good amount of testing to get that one in the ball park. Hopefully your numbers are lower than they say.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jul 2012
    Herndon, VA
    419
    Regarding partially draining the pool and refilling....
    Should I wait until CYA is in an acceptable range before I add any thing else to balance or sanitize?
    May 2011
    Clearwater, FL.
    446
    Just to be sure....
    If you feel like your overwhelmed with this chemistry thing like I was, I bought the XL kit so I could test more often and help with my slow learning curve. That helped a lot for me.
    If your going to a SWG then get salt testing kit.
    Do you know if you have any suspicion of copper in the pool previously?
    If so they have a copper test kit.
    I went a year before I got a speed stir (I was being cheap) but I do like it now I have one, the testing goes faster and simpler.
    Chuck
    TF-100 test kit
    May 2011
    Clearwater, FL.
    446
    I would at least add bleach or liquid chlorine if the waters still clear to help from losing the pool to a major algae bloom (turn to swamp).
    TF-100 kits get shipped same day most of the time from http://tftestkits.net (fantastic service from Dave and Meg)
    Chuck
    TF-100 test kit
    Jul 2012
    Herndon, VA
    419
    With CYA levels this high (250 range), might it be more practical to have the pool professionally drained and refilled? Any idea how much that costs?
    22,553
    You can normally drain and refill your pool yourself. However there are some considerations depending on what type pool you have and where you're located.
    What pool do you have (type, size, etc.)?
    Are you in an area with a high water table?
    I wouldn't do anything except put a jug of bleach in the pool until you get the new test kit and know for sure what the levels are.
    Jul 2012
    Herndon, VA
    419
    I have a fiberglass pool, so a full drain is not possible to do without professional help, correct?
    My pool is a fiberglass, 12,000 gallon, kidney shaped pool...
    My cyanuric acid levels are the concern....in the 250 range. I'm only draining from about mid skimmer level to about three inches below that, and then replacing the water. This seems like it would take quite a long time to get my CYA levels to proper levels.
    30,432
    Actually, it's quite easy to do it yourself. It is done in a series of partial drain/refill steps.
    bmann71's Avatar
    Aug 2007
    Washington, Indiana
    55
    Another option that has been done is since yours is in the medium size pool range you can get a tarp or plastic sheathing larger than the pool (you can duct tape pieces together if need be) then place it on top of your pool and fill the pool to the top. Drain down just below skimmer and repeat the process till you've changed the water then just remove the plastic.
    Ponduke
    20,000 gal/ Fiberglass IG/ Sta-rite s7m120 cartridge filter/Sta-rite SR400NA 400,000 btu heater/Polaris 360 Cleaner/K-2006 Test Kit
    poolcalculator
    Pool School
    22,553
    As mentioned above, it's not hard at all to do. You can also take a tarp and weigh down the bottom and float the top (like a curtain wall) and drop it in one end of the pool and start filling behind it and emptying from the other end and it'll slowly move toward the other end as you fill/empty the pool. then when it's almost to the other end you can take the tarp out and let the water mix. Even without the tarp you can fill the pool in one end and empty out of the other and it works pretty well.
    Jul 2012
    Herndon, VA
    419
    So I should be filling and draining at the same time?
    Tonight I filled the pool past the skimmer, almost to the top...
    Then I drained the pool to just above the danger line on step 2 of my pool (this black sticker on the step is where I can safely drain to, according to the previous owner's pool service company).
    Now, I'm refilling the pool with the hose, from the shallow end. I just added about 2 gallons of 6% regular clorox to the water as well.
    Sound about right?
    Jul 2012
    Herndon, VA
    419
    Update: I've got the TF-100 kit on order. I went with some of your recommendations as well and got the XL option as well as the speed stir.
    My tablet chlorinator still has about 1 and a half trichlor tabs left in it. I plan on letting it dissolve completely and never add them again until I get my CYA level to the 30 - 50 ppm range.
    I'm a bit confused as to what my next step should be, and in what order things should be done. If anyone can let me know what I should be doing and in what order, I'd really appreciate it.
    22,553
    It works better if you fill and drain at the same time. However your way works too.
    Once your test kit gets there we'll know more about how far you have left to go.
  20. Back To Top    #20
    Jul 2012
    Herndon, VA
    419
    Ok...so, drain by turning off the skimmer, and drain solely from the main drains?
    At the same time, and at the shallow end of the pool, I should be adding water?
    What about the fact that the draining goes faster than the refilling by hose?
