Thread: Leveling an Oval Pool
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Okay this probably a pretty stupid question but here goes.
    I understand how to level a round pool by the 2 x 6 half the width of the pool and taping a level on top with duck tape.
    But how would you do if for a oval pool and to make sure it was all level?
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Leveling an Oval Pool
    I would probably use a surveyor's transit.
    Guest
    I did 3 circles, inline of course. Then I used a transit for final grading. Also a properly chosen 2x4 will do the trick as well as a 2x6.
    Jul 2007
    Hillsborough, NC
    519
    I used my laser level I got a Lowes. A surveyor's transit would have been easier except I don't know how to use one, and renting one costs 4x as much as buying the laser level, which I now own for other projects like the ceiling I am doing later this summer.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
