Thread: Finally got my test kit!!! Results below
    Jun 2012
    1 1/2 hours south of Chicago
    320
    FC 10.5
    PH. 7.5
    CYA 56
    CC 1
    Im going to continue shocking until i loose no more than 1 pp overnight. Anything i am missing let me know. looking forward to gettting my saltwater back up and running.
    Tracy
    Vinyl 16X48 Intex pool with SWG
    Pool holds 5061 gallons of water Using Taylor k-2006 test kit
    Intex Krystal Clear 1,600 Gallon Sand Filter and Krystal Clear SWG
    30,408
    Re: Finally got my test kit!!! Results below
    Hi, Tracy,
    Unfortunately, you haven't started to shock just yet. Looking at the FC/CYA relationship chart in Pool School, a CYA of 60 (56) requires a target value of 24ppm FC to attain shock. Importantly, you must constantly replenish your FC to keep it at 24ppm until your water is crystal clear.
    You are missing tests for TA and CH although they are not very important while you are clearing a pool.
    Jun 2012
    320
    Hi, Tracy,
    Duraleeigh i have been working on this pool for over a week...it was very green i have another post under the BBB method. we are starting a new filtration system on this pool tonight and then eventually adding our SWG back to it. Thanks for your information and i am trying to learn everything at once here so my kids can enjoy a Crystal clear pool before school starts in a month. we had the pool to where we could see the bottom yesterday and was looking very good until hubby went to vacuum and everything just started shooting out the outflow and now everything is cloudy!!! I read this in BBB for beginneres Vinyl pools without a spa should keep CH anywhere under 300, which usually means you don't need to worry about it much at all.
    I've been keeping my FC at 20 ppm and my cya target was 50 but went a little over not to concerned because by thee time the kids get in and splash. I also tested in th middle of the day because i was excited to get my kit and gt my own results, so considering this morning my FC was bought bacck up to 20 and its been really hit and full sun toDAY. tonight i will test again and bing back up to 20 if need be.
    Tracy
    Jun 2012
    320
    Night test results
    FC 14.5 Need to add 2.5 ozs of Bleach
    CYA 50 FOrgot i added water the other day we were low 6.8 ozs of stabilizer
    PH 7.8 add 13 ozs of Muriatic acid
    Hubby is home with new filter, is eating then gonna get that hooked up
    Any suggestions are greatly accepted and appreciated!! thanks i dont know know if i should ask this here but when should we hook our SWG back up?
    Im sure i forgot something im new to the liquid testing
    Tracy
    Feb 2008
    Denton, TX
    5,061
    Don't use your SWG until you are finished shocking. Don't allow swimmers until you are finished shocking. You are finished shocking when you have 1.) CC less than or equal to 0.5, 2.) A FC loss of no more than 1 ppm overnight, and 3.)clear water. Until you have ALL 3 of these things, you are not finished shocking and you will continue to have problems. If you do not follow the shocking instructions in pool school fully and completely and all the way through, you absolutely will continue to have algae. So if your shock level for your CYA level in your pool is a FC of 24, then bringing it to 20 isn't going to work for you. Bring it to shock level, KEEP it there, and do so until the three conditions that I mentioned above are all met.
    Jun 2012
    320
    ok so for aFC am i going by a regular cya or swg pool cya? Because its two different numbers to be at so i dont know which numbers to follow,Pool is not green just cloudy..we picked up the new sand filtration filter last night and have been running it and im using the taylor test kit..swg has been turned off since the pool had went green.
    Tracy
