Thread: SWG vs Bleach
    Aug 2011
    Frisco, TX
    26
    SWG vs Bleach
    Does anyone have some specific details about a comparison? All I could find was 1 pound C12 gas = 1 gallon sodium hypochlorite = 1.5 pounds calcium Hypochlorite = 1.75 pounds dichlor = 1.15 pounds trichlor = 2.8 pounds lithium hypochlorite. Not sure how accurate this is but if I do a simple conversion i get below.
    Right now I am running 80% for 10 hours a day which according to my calculation is 43.56 ounces a day of 6% Bleach. Seems pretty close to what I was using before I got the new IC20 hooked up.
    IC20
    % runtime Hours SWG CL Production 12.5% Equiv 6% Equiv
    100% 24 0.7 89.6 186.67
    80% 10 0.234 20.9 43.56
    100% 10 0.291 26.1 54.44
    14,000 Pebble Sheen Salt Water Pool All Pentair Equipment/ Cartridge Filter, 400K BTU Heated.
    Re: SWG vs Bleach
    Your conversion factors look about right, give or take that cal-hypo comes in several different purities.
    I wouldn't expect your total chlorine usage to have changed unless you also changed your CYA level or target FC level. Of course, both of those usually change when you switch to a SWG.
