Thread: Dolphin Pro in Above Ground Pool
    Sep 2011
    Omaha, NE
    95
    Do anyone know if the Dolphin Pro cleaner can be used in an above ground pool? It states it is for an in-ground, but I am not sure why it can not be used for an above ground......
    I found one on CL for $200 and thought that was too good a deal to pass up...
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Re: Dolphin Pro in Above Ground Pool
    Hi Fritz, I think the reason you cannot use an in ground pool cleaner on your above ground is due to the fact that when the robot climbs the walls of your pool, the vibration may damage your pool walls. The cleaners made for above ground pools do not climb the pools and consequently can't damage your pool walls.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
