Results 1 to 17 of 17
Thread: Help ants everywhere climbing up the pool and diving in
    How can i keep the ants away from the pool these little critters are crazy. They actually climb the pool and dive in. I have been spraying around the pool before we swim and when we get done but they come right back as soon as the kids start splashing. Any suggestions.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Help ants everywhere climbing up the pool and diving in
    Boric Acid. 20/20 mule tam will work. Dust the ant area with it, they think it's food and bring it back to their queen. Best to find where they're coming from though. Don't let the kids eat it either. It is poison. Kills fleas too.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by frogabog
    Is there any issue with pets like dogs eating the stuff?
    Black flying ants here. When they bite, they leave a mark and it bruises. I'm in SC
    20 x 48 Intex Ultra Frame
    Sand filter with SWG attached.
    Deck added on (05/18/2013)
    Thinking about adding more deck
    Pool steps added in - (got rid of that crappy ladder that came with Intex pool) 05/18/2013.
    "A little bit of paradise in our yard"
    If you're using an ant killer from one of the big box stores, it most-likely is weak and washing away. I suggest looking around doyourownpestcontrol.com or domyownpestcontrol.com and finding both a sugar-based ant bait, as well as a protein-based ant bait. Baits are important, because the ants will carry it back to their next and kill the colony. Now, understand that you won't see instant results from a bait, but in the end, they'll do much better at telling the ants they're unwelcome. Most spray ant killers are generally regarded as safe, once they have dried, so pets and children should be OK. Some even have a residual affect if they are properly applied. Make sure that you don't apply the big-box store "insect barrier" products near the baits, as the "insect barrier" stuff contains a repellant, which will prevent the critters from taking the bait.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    http://www.terro.com/products.php?produ ... shaker_bag
    Seriously, you will never have ants again. Dust around your pool and house.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Quote Originally Posted by Glock
    http://www.terro.com/products.php?product=ant_shaker_bag
    Terro granules are protein-based. If the ants are full of protein from some other source, they'll ignore it an go on looking for water and carbohydrates. However, if they're hungry for protein, it should work fine.....as long as they're not carpenter ants, which don't die from borax. (black, 3/8" - 1/2" in size).
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by UnderWaterVanya
    I wouldn't use borates/boric acid if you have pets who can eat it. In it's concentrated form it's toxic to animals in general though it takes more than just some sprinkles. See the Are Borates Safe to Use? thread for more details. The lethal dose is around 500 mg per kg of body weight so about 6 times worse than table salt, but first symptoms were seen with dogs at 29 mg/kg/day (about 2 tablespoons per kilogram of body weight per day).
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    What do you use for carpenter ants?
    May 2011
    Ft. Lauderdale, Fl
    39
    I have 3 dogs and have used borax on my carpets as a flea treatment. I sprinkle it on the carpets and let it stay there for a couple of weeks to dehydrate flea eggs. My dogs have never gotten sick from it...they are b igger dogs ranging from 50 to 80lbs. My sister used the same treatment for fleas and has 3 cats...no ill effects. I would feel comfortable using Borax to treat ants with pets/kids around. just my 2 cents and my experience...only do what you're comfortable with.
    32x16 -16,500 gallon plaster pool with connected spa and spillover, Hayward RS 1 HP pump, 2 Hayward Cartridge filters. 10 hours of direct sun a day and a first time pool owner!!
    SE Minnesota
    91
    I use cornmeal. Grocery store cornmeal in a the can. You should be able to find where the hills/nests are, at least somewhat of the path. Sprinkle it over the area and around it. They eat it, but can't digest it.
    Mona SE MN
    24' round 48" high AG
    Meteor Sand Filter
    1.5 HP pump
    Jun 2012
    Mint Hill, NC
    2,589
    RE: Cornmeal...
    I have not been able to find any reliable sources to validate this method. At least one source (SNOPES.COM) pointed me to this reference: http://www.homegrowntexas.com/issues/Se ... index.html
    However the references above is not directly in conflict with the idea that the larva may not be able to properly digest this. My own guess is that even if this is true - the ants would stop bringing this food and switch to another food if the product was not digested properly.
    In any case - if there are references that show that this is true - I'd like to see them.
    Here is one person's test of DIY remedies:
    http://www.diylife.com/2011/06/27/testi ... d-of-ants/
    Note that cornmeal did not work but there is no clear timetable and the testing may have stopped too soon. I'd really love to see someone test this in a controlled environment.
    hydramethylnon
    thiamethoxam
    fipronil
    Imidaclopid
    Abamectin B1
    http://store.doyourownpestcontrol.com/m ... t-bait-kit
    http://www.domyownpestcontrol.com/carpe ... -1054.html
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Quote Originally Posted by Seattle2k
    hydramethylnon
    thiamethoxam
    fipronil
    Imidaclopid
    Abamectin B1
    Thanks.
    I use ground Cinnamon in places where pets are and it works great, if you have ants in the house like on the kitchen counter where you don't want to use poison. You will have to make sure it stays dry for a little while but once the ants walk through the cinnamon it gets in their joints and burns and they go back home and tell the other ants not to go that way. I know it sounds crazy but it works.
    I live in the woods near the Sam Houston National Forest in Texas.
    Carpenter ants have been bad these last two years due to mild winters.
    I use grits. Uncooked grits poured at the base of each tree every 3 days for 9-12 days and they are gone. I have NOT looked up the adult life cycle of a carpenter ant but the first two or three days (the first week) kills the adults and the extra days are for the newly hatched ones.
    It works for me. I buy several five pound bags of uincooked grits and pour about 1/2 cup at the base of each tree. I have many, many trees so maybe one five pound bag should work.
    Hope this helps,
    Marti (My first post!)
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP! Thanks for the tip.
