Results 1 to 19 of 19
Thread: Easiest way to plumb outdoor kitchen
    I am planning an outdoor kitchen and am looking at running cold water only from the house. It will be about 30 -40 feet from the house. I think I will be digging a hole and burying a 10 gallon bucket filled with gravel for the gray water.
    My only question is what is the easiest way to get water out there?
    I have a garden hose faucet in the back, can I cut that line under the house, install a Tee and hook that back up and split off to the outdoor sink?
    If I can do I just drill through out brick go out with the pipe then straight down into the ground t the sink?
    Can I use standard 3/4 rigid PVC to run the line or does it need to be flex hose? Not planning on drinking the water, just washing out glasses,hands, maybe vet garages before putting on grill , exe.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Also should I run the plumbing up through concrete or just stub it up In the back of the planned bar area right next to the concrete pad. This is a new build btw.
    Re: Easiest way to plumb outdoor kitchen
    You should be able to do just as you said and tap into the faucet line with a T and pull the feed off of that but you might want to put a shut off at the house end for freeze protection, etc. I am planning a cold water sink/shower out by my pool so I ran 1/2" pvc from the house to the edge of the equipment pad in the trench my electrician used for the panel. Mine is currently capped on both ends but I plan to tap into the house line and put a shut off on the line just after the T so I can shut off that line in the winter to protect from freezing (we tend to get cold weather here in Maryland). As for running it up through concrete, doing that is not necessary but will make the install more permanent (be that good or bad).
    18'x36' IG Gunite Custom (Lazy River), Granite Sunstone quartz finish, 1.5hp Jandy ePump (Variable speed) with ePump remote, Jandy CS200 cartridge filter, Nature2 Fusion, and 18" stepped raised bond beam with 24" sheer descent.
    Quote Originally Posted by msudawg
    Thanks for the reply! I live in Alabama and although we do not have harsh winters we do have freezing temps at times so I will defiantly put a shutoff after the tee under the house.
    Did you use rigid PVC or flex?
    Did you just drill through the foundation and go straight downinto the ground?
    I used rigid pvc and where it enters the house I came up above grade and came through the foundation wall with a hammer drill.
    Aug 2010
    New Caney, TX 77357
    184
    Maybe I am missing something but is there a reason you want to go through the slab rather than installing the tee outside (ahead of the existing faucet valve)? This is what we did to get water to our kitchen.
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    Quote Originally Posted by Stevereno
    Do you mean installing a Tee in between the house and faucet so the garden hose faucet sticks out from the house?
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by kyle11
    Yes, that's what I am saying. If you do that you can run the new line straight down into your trench without making any slab/brick penetrations. I understand that may not be the most aesthetic way to do it but you were asking about the "easiest" way.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    I'll give you an example of what I did and how I hooked it up. I teed off of PVC in my downstairs bedroom with 3/4" rigid PVC that ran out to an outside faucet. I ran the T'd section to the location where both my electric and gas went to my new pool. Ran rigid 3/4" PVC through that 3' ditch out to the pool house. Prior to leaving the house, I've got a valve attached (bicycle valve) that is used for winterizing each year. I also have another valve closer to the pool house. Once in the pool house, I've got a water heater and run water to a shower, 2 sinks, icemaker, underground frost free faucet, a simple outdoor faucet and an autofill to my pond. We drink the water full-time and drain the shower/sinks into a buried 55 gallon trashcan filled with clean gravel. Works great and went through one winter of winterization with no issues. Most of my lines are buried at about 1-3 feet below grade, so there is a risk of freeze here in MD, but blowing out the lines each winter will minimize all the risks of frozen pipes. I sure don't want to re-run any of these lines. I've got bluestone over all those areas. I also took some detailed photos of all my runs and installations for future reference. They will help immensely in the future if I run into problems.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Ok thanks Steve, that's what I thought you was referring to. That would defiantly be the easiest way but I don't know of I could swing that by the wife as the faucet I would have to hook up to is very visible from out back porch/ pool area. That is defiantly an option though.
    Quote Originally Posted by XsAllOverIt
    Thanks that helps.
    Did you stub it up through concrete or just run it to the back of the building and in through a wall?
    Also can standard PVC be used or does it need to be sch40? I would imagine sch40 is not needed but do not know for sure.
    Aug 2010
    New Caney, TX 77357
    184
    Yeah, that's always an issue.
    I will try to post a picture tonight. Not having much success from work PC.
    Dec 2010
    560
    Thanks that helps.
    Mine was all run prior to any work. I've got a lot of pictures of my entire build.
    http://www.golfmd.com/baurphotoalbum/po ... seII-4.htm
    At the bottom of this page, I run from the house to the pool house. My pool house wasn't really complete so all the plumbing came up from the ground into the pool house which is on concrete pillars as you can see.
    TFT-100 test kit
    Thats a very impressive build! We are still trying to decide on what we want really. I kind of want to take elements from a pergola/gazebo and also elements from something like you built. I like walls that a pool house provides but I want a completely open front with no doors, maybe a bar extending half of the width. I just can't decide, luckily we still have a little while before we have to.
    i would use 1/2 pex pipe... much better in case of a freeze situation, you need a tool but you can rent one for the day
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    Quote Originally Posted by mikeginder
    I 100% agree, Pex is the way to go. It's very easy to run because of its flexibility over PVC, and it's tough, not thin walled like the old poly piping. Most new house builds use Pex instead of copper, and I've replaced some of the copper in my house with Pex when needed. I know how to sweat copper, and I have no problem doing it when necessary, but if I can replace copper with Pex, I do.
    You'll need two tools; a good quality hose cutter (>$10), and a good quality Pex cinch clamp tool to clamp the stainless steel cinch clamps ($50). I have a Kobalt brand cutter and a Kobalt crimper that I bought at Lowes, and they've worked fine for me over the years.
    Quote Originally Posted by Lonstar
    i have the kobalt stuff and can sweat pipe as well and i also use pex when i can... and if out in the open i use the heck out of shark bites as well..
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    I know this really late, but I had mine pumbed right from the indoor kitchen sink through the wall and and tied into my out door sink and cabinet. Using the same drain as is inside. My cabinet is a little taller and is on wheels it makes it much easier to move if I need to for any reason.
    Jun 2013
    Huffman Tx
    190
    I came off the exterior hose bib ,with a tee/valve then a 12-14'' Galvenized pipe into the ground . its nice to be able to weed whack & mow around metal. pipe then run underground with whatever ..
